New car headlamps upgrade
Been thanked: 86 times
Post by Coupe Racing » Mon Nov 07, 2016 11:04 pm
Just taken delivery of a new modern
Nissan Qashqai , and the headlights are terrible.
Its not just me - various forums echo my thoughts.
OEM is LED day time lights , and Halogen dip and main beam.
What are the upgrade options ?
After market bulbs like the Philips RacingVision http://www.autoexpress.co.uk/accessorie ... group-test
Or LED replacement bulbs ?
I wont go HID and could not afford the Xenon option
Can I go LED replacement bulbs ?
*JP*
Been thanked: 14 times
Re: New car headlamps upgrade
Post by *JP* » Tue Nov 08, 2016 11:23 am
Those Phillips upgrade bulbs will be a worthwhile improvement.
The other thing to look at is the adjustment.You can find that even with the dash adjuster on its highest setting the range is inadequate but there will be under bonnet adjusting screws that you can tweek to get a better range on the beam...not so much so as to dazzle other drivers of course.
HID/Xenon....are they not the same thing?...legality or other wise of conversions,need for washers etc. Been done to death on forums,personally I wouldn't go there.
Led bulbs as a conversion are interesting but I have no knowledge...but apparently with led headlights washers are NOT a requirement,so worth investigating.
Been thanked: 210 times
Post by AJL Electronics » Tue Nov 08, 2016 12:58 pm
Washers etc are not required for HID. The rules say IF FITTED they must work, not that they have to be fitted.
Been thanked: 842 times
Post by scimjim » Tue Nov 08, 2016 2:51 pm
"done to death" because VOSA issued an MOT special notice regarding washers and self-levelling for HiD lamps - but when the manual was eventually re-issued they'd changed "must have" to "may have" and "where fitted, must work".
fightingtorque
Post by fightingtorque » Tue Nov 08, 2016 4:15 pm
Long (and mainly positive) thread on LED replacement bulbs here, in a TVR : http://www.pistonheads.com/gassing/topic.asp?t=1455474
I'm thinking about it - I have halogen conversion on my SE5 and it's good on main beam but fairly rubbish on dipped. In general, I don't plan to drive it much in dark or miserable conditions though.
td99
Been thanked: 22 times
Post by td99 » Tue Nov 08, 2016 7:54 pm
fightingtorque wrote:Long (and mainly positive) thread on LED replacement bulbs here, in a TVR : http://www.pistonheads.com/gassing/topic.asp?t=1455474
That's an interesting thread. Took a while to skip through the 22 pages...
Providing the heat sinks of H4 LED's will fit under the cowl, would be so much easier than fitting HID to SS1 (the moving pod makes placement of the ballast tricky if wiring not that long).
Trevor - 1800Ti daily driver
1800Ti DET project, RAV4
Been thanked: 113 times
Post by ScimmyMike » Tue Nov 08, 2016 8:22 pm
Thinking of goind LED route with my coupe when I finally get it rebuilt, if you go that way be interested in the results Steve, oh I've come across this site when looking, don't know whether of any use for you.
http://www.classiccarleds.co.uk/collect ... -led-bulbs
Post by Coupe Racing » Tue Nov 08, 2016 10:37 pm
I've now found that the latest LED bulbs have not only done away with the fan and heat sink , but some also have the ability to adjust the focal point
Seems to be mixed results
The old reflector technology of old cars seems to create beam pattern problems whereas modern lamps are ok
I'm looking at some H11 and they are plug and play and dimensionally identical and cost about the same as decent uprated halogen bulbs
Post by Roger Pennington » Wed Nov 09, 2016 12:43 am
ScimmyMike wrote:Thinking of goind LED route with my coupe when I finally get it rebuilt, if you go that way be interested in the results Steve, oh I've come across this site when looking, don't know whether of any use for you.
Those certainly look interesting Mike :)
Return to “Other Car Chat”
