Ness the t4
Re: How dead am I!
Post by greeny » Sun Apr 24, 2016 2:59 pm
The guy I got it from says that the diesel pugs his neighbours have run on it and they have said it works out about 67p a litre! However we shall see.
Has thanked: 249 times
Been thanked: 223 times
Re: How dead am I!
Post by CNHSS1 » Sun Apr 24, 2016 3:16 pm
Tell her ya bought it so you could go away for romantic weekends away, it was a present for you both ;-)
79GTE
Re: How dead am I!
Post by 79GTE » Sun Apr 24, 2016 4:00 pm
I ran my old transit on veg oil. I came back from Anglesey in the transit on just veg oil a few times and it ran no different. Just was told to change the filters more often but I didn't. And now you have to pay tax on it I don't think it works out much cheaper then normal diesel at the pumps.
Re: How dead am I!
Post by greeny » Sun Apr 24, 2016 4:10 pm
CNHSS1 wrote:Tell her ya bought it so you could go away for romantic weekends away, it was a present for you both ;-)
You have done that before!!
Re: How dead am I!
Post by CNHSS1 » Sun Apr 24, 2016 4:11 pm
That obvious huh? ;-)
Re: How dead am I!
Post by greeny » Sun Apr 24, 2016 4:12 pm
79GTE wrote:I ran my old transit on veg oil. I came back from Anglesey in the transit on just veg oil a few times and it ran no different. Just was told to change the filters more often but I didn't. And now you have to pay tax on it I don't think it works out much cheaper then normal diesel at the pumps.
I have heard that it would run on just veg oil in summer but needs the diesel to thin it in winter?
Re: How dead am I!
Post by greeny » Sun Apr 24, 2016 4:13 pm
CNHSS1 wrote:That obvious huh? ;-)
Yes!! But in my case won't work as she ain't speaking to me!!!
So roast dinner on with nice pud and loads of creeping!!
Been thanked: 34 times
Re: How dead am I!
Post by Will Anderson » Sun Apr 24, 2016 5:47 pm
greeny wrote:I have just applied Mr Hughes adage of forgiveness is easier than permission! So with out permission from swmbo I have been out and bought a
VW T4
Huh, think that is dangerous, I'll see your T4 and raise you a Middlebridge. :oops:
mikerf
Re: How dead am I!
Post by mikerf » Sun Apr 24, 2016 7:29 pm
I used to run my Hilux Surf on Veg oil and diesel on a ratio of 3-1 and it ran perfectly. I stopped when veg oil started costing more than diesel. However, you need to be aware that it will be very obvious you're using veg oil as you can't help but notice the chip shop smell. The other point is that you should be paying duty on the oil used, failure to do so can result in a substantial fine. Happens more often than you might think. I got pulled over and had my tank dipped by HMRC once when they were checking for unauthorised use of red diesel.
You have been warned.
Re: How dead am I!
Post by greeny » Sun Apr 24, 2016 7:35 pm
So if you pay duty on the veg oil in the first place is that ok? I was thinking costco as a supplier as they do big drums.
Re: How dead am I!
Post by greeny » Sun Apr 24, 2016 7:37 pm
VW T4
I raise that with the X type a triumph acclaim and a coupe!!! Coupe and triumph now sold though.
Been thanked: 842 times
Re: How dead am I!
Post by scimjim » Sun Apr 24, 2016 8:53 pm
greeny wrote:So if you pay duty on the veg oil in the first place is that ok? I was thinking costco as a supplier as they do big drums.
No, that's duty at normal rate (20% VAT) - if you use more than 2500 litres pa you must pay fuel duty (another 30 odd pence per litre last time I looked)
Edit - a quick google suggests it was 58p in 2013 :shock:
Re: How dead am I!
Post by scimjim » Sun Apr 24, 2016 8:56 pm
Exempt Producers and Users
If you produce and/or use less than 2,500 litres per year of biofuel, and expect to continue at or below this rate of production/use, then you are considered to be an exempt producer. In this case you do not have to register with HMRC, nor do you have to pay any duty. You are however legally required to keep records of a) the date of each supply and/or use, and b) the amount of supply of own use. These records must be preserved for six years.
Been thanked: 113 times
Re: How dead am I!
Post by ScimmyMike » Sun Apr 24, 2016 9:20 pm
If it's a PD VW engine just check before bunging anything other than proper diesel into it, could be short term gain from what I recall when running a PD Audi A4
79GTE
Re: How dead am I!
Post by 79GTE » Sun Apr 24, 2016 9:34 pm
By the time you pay the duty it works out no cheaper then normal diesel. I just put normal diesel in now as not worth the hassle.
Return to “Other Car Chat”
