Bond Equipe GT4S.
SRF
Has thanked: 93 times
Re: Bond Equipe GT4S.
Post by SRF » Mon Feb 09, 2015 10:02 am
scmarf wrote:2 x documents PMed.
Exhaust can be ordered from TSSC. We made one up from Herald and Spitfire parts (see documents) but it is quite noisy so the proper system might be a better bet if you are starting from scratch.
Documents gratefully received.
Ray
Reliant Scimitar SE5 1971. Already restored Sunbeam Rapier,Morris Minor,Rover P4, and Triumph Vitesse. I have also restored 8 classic tractors over the past 18 years. My latest project is a Bond Equipe GT4s
SRF
Post by SRF » Mon Feb 09, 2015 5:47 pm
greeny wrote:Just a thought on the exhaust why not price a longlife one? Branches all over the country and good price too! a number of RSSOC members have used them with no issues!
I have asked for a quote their nearest branch is Chester, not far away. Thanks for the info.
Ray
Post by greeny » Thu Feb 12, 2015 11:59 am
Topgear Stockport is where The highpeek lot go.
They must have had a significant amount of money out of us over the years!
SRF
Post by SRF » Thu Feb 12, 2015 6:35 pm
Not had a reply, so I might try Topgear Stockport.
I want to get the engine running so I can assess it's condition. at the moment the whole cooling system is dry and appears to have been that way for some time. Could I use waterless coolant without using the preparation to purge the system. It may be an opportune time to change.
Ray
philynnbob
Has thanked: 65 times
Post by philynnbob » Thu Feb 12, 2015 8:23 pm
scmarf
Post by scmarf » Fri Feb 13, 2015 1:02 pm
Oooh looks tasty - but then with £10,000 spent for the restoration .... :shock:
Ours cost £250. It was the registration number that clinched the deal (KEV 895C)
Respray cost £150 plus another £20 for the bubble wrap around the garage walls.
Happy days :)
Honda Jazz
Been thanked: 118 times
Post by ScimmyMike » Fri Feb 13, 2015 1:13 pm
I quite like that, nicely finished by the look of it
SRF
Post by SRF » Fri Feb 13, 2015 6:01 pm
philynnbob wrote:Have you seen this one on Ebay?
http://pages.ebay.com/link/?nav=item.vi ... 1772615791
Looks a thoroughly restored car, the colour looks good. I hope he kept the original engine after he replaced it. The Equipe has a 4.11 diff which, if it is like the Vitesse makes the engine rev hard at anything over 50 mph. An overdrive like the one fitted to this car is a good adaptation. The only problem is that the world and his wife want overdrive boxes and the prices are high. I have 3.63 crown wheel and pinion which I was going to fit to the Vit but never did, this is another way to lower the revs of the engine. The third option is to fit larger wheels. I believe 15" ones from an MGF fit but that is a big jump.
Ray
Has thanked: 229 times
Been thanked: 112 times
Post by MikeyBikey » Fri Feb 13, 2015 6:38 pm
Hmmm what is the mustard coloured car to the rhs in the first picture :?:
SRF
Post by SRF » Mon Feb 16, 2015 3:55 pm
I have spent time going through the boxes of parts. I have started an inventory of the parts and what is missing. The main things missing. apart from the exhaust system is the sills. I am hoping that being based on a Herald the standard ones ,which are readily available, will fit. The PO has done some welding repairs to the bulkhead which are to a high standard, but one of the inner sills is only tacked and wants finishing off.
I don't want to get side tracked from finishing the Scimitar, a lot of the remaining jobs are warm weather ones, so I can do a few small jobs on the GT4s.
One job not so small it to lift the body off the chassis, the bulkhead can remain where it is. If my engine crane won't do the job I am going to fabricate an A frame and lift it with a hoist. I can then drop it onto a trolley so it is moveable. I will then push the chassis onto my scissor lift where I can work at a comfortable height.
Ray
scmarf
Post by scmarf » Mon Feb 16, 2015 8:16 pm
SRF wrote:I have spent time going through the boxes of parts. I have started an inventory of the parts and what is missing. The main things missing. apart from the exhaust system is the sills....
Certainly the outer sills are Herald but thanks to the 'bespoke' construction by Bond, I had to add about 1 inch extra length to one of them :?
I dont think you need a crane to lft the body off - just a couple of friends. It only takes 3 people to lift a Coupe shell!
Honda Jazz
SRF
Post by SRF » Mon Feb 16, 2015 10:05 pm
Unfortunately fit strong young men are not in my circle of friends. We are more like last of the summer wine.
Ray
scmarf
Post by scmarf » Mon Feb 16, 2015 10:12 pm
Local noggin? I've found that a selection of beers is usually enough to muster enough muscle power.
Honda Jazz
SRF
Post by SRF » Tue Feb 17, 2015 12:35 pm
I have found a company that do fibreglass sills. I wouldn't put them on a steel car but may be in keeping with the Bond. They are roughly same price as steel and will be as easy to extend.
Ray
SRF
Post by SRF » Sun Feb 22, 2015 5:19 am
I completed the first job yesterday, great access to the engine, you can either perch on the front wheel or use a chair like rotund OAPs do!!!. I removed the exhaust manifold and carefully drilled out the 2 broken studs. I then chased the threads with the correct size tap. I have new studs gasket and brass nuts on order. There are a lot of traders supplying parts for Triumph cars and a few minutes on the internet can save money.
Ray
Return to “Other Car Chat”
