Restoration of 1965 Elan S2
GeoffTE
Been thanked: 26 times
Re: Restoration of 1965 Elan S2
Post by GeoffTE » Wed Dec 31, 2014 11:36 am
Thanks, but the problem with the Elan is the depth of the radio, most common radios are too deep. I think that the Blaupunkt, even the older ones, is one of these. There is only 125 mm or so to work with, but thanks for the offer anyway.
Geoff. (5324)
GeoffTE
Post by GeoffTE » Wed Jan 07, 2015 8:36 pm
Finished off the electrics ( thank goodness) and I think that everything now works. Not without the usual anguish though :w The horn on the Elan is a strange arrangement in that the central horn button when pressed earths against the central column. This, in turn. can only be earthed if a by-pass wire is connected from the rack across the U/J joint at it's base. This U/J has rubber grommets which insulates it from the column, hence the need to by-pass. I also had problems with the indicators, which, although I checked and rechecked, it STILL turned out to be B.......EARTHS ! :evil: Mind you the flasher unit also failed half way through which threw further confusion into the mix. So steering wheel fitted and gear lever in
Sorry the pic is a bit blurred.
The steering wheel is a bit on the large side I know, but it is an original and these days these command a four figure sum :shock: IF you can find one!
I've also fitted the original Marsten radiator, which are also like rocking horse poo to find these days
Coming together quite nicely now, although I'm in constant pain these days :cry: I have to do a few jobs underneath the car next; connect up slave cylinder, speedo cable and a few other bits, but the main job is the exhaust. I've managed to get the car up on the car ramps at the front, which give me a bit more room, but crawling underneath is hard !!!....and getting out again even harder :roll: :D Still when this is done there really isn't any excuse for putting off trying to start her up! Always an anxious part of a resto I always think !
Geoff. (5324)
Has thanked: 212 times
Been thanked: 104 times
Post by MikeyBikey » Wed Jan 07, 2015 9:03 pm
Brilliant stuff geoff.
Been thanked: 50 times
Post by Elizabeth's dad » Wed Jan 07, 2015 9:48 pm
Stunning work Geoff. You'll need to dress like Emma Peel (in the black & white series) when you drive it!
GeoffTE
Post by GeoffTE » Wed Jan 07, 2015 10:06 pm
Yes Jim, I've already bought the black leather cat suit :mrgreen: ......my problem is I can no longer get into it after all the Christmas fare : lol: :lol: :lol:
Geoff. (5324)
Post by Elizabeth's dad » Wed Jan 07, 2015 10:17 pm
I look forward to our next meeting. :wink:
Post by Scimher » Thu Jan 08, 2015 12:01 pm
...Great stuff!....The horn arrangement, steering column joint hoo-hah, all sounds like my little Herald - I presume there was more in common than just the front suspension.
At least all this scrambling around will be keeping you 'young & nubile', Geoff!!!...Plus, of course, working off the 'Christmas fare'.....................
GeoffTE
Post by GeoffTE » Fri Mar 06, 2015 9:19 pm
Update on the Elan rebuild. Exhaust system fitted (not without issues as usual :roll: ), brakes bled....eventually....front calipers needed swapping left to right to allow proper bleeding :oops:, attempted engine start, but initially no fuel flow. Fitted one of those rubber primer bulbs that are used on marine outboard engines and primed the carbs before attempting a start. Pressed the button and.....immediate start :hurrah: (Thinking of fitting one to SAR) Some tiny adjustment on the dizzy and tickover/mixture and she ran well. Lots and lots of smoke as surplus oil on the exhausts etc burnt off, but she always starts first time now....very very chuffed :mrgreen: One problem was that the tacho was reading too high, about double the correct revs I reckoned. I fitted Accuspark electronic ignition and reading up and asking advice it seems this was the issue. I was able to take the tacho apart, halve the turns on the coil and adjust the revs. All now well, although I've had to return the new combined oil/water gauge as it was faulty :( Still waiting for the replacement :( :(
Getting close to fitting out the interior and rebuilding the doors. Already had the door handles re-chromed and some window channel remanufactured in polished stainless sttel. Should anyone be interested in a fuller account of the rebuild and the issues I've had then visit:-
Lotuselan.net, Forum
then; Elan Discussions
then; Restoration of S2 Elan EOK, by "Geoffers71"
Some pics:
Geoff. (5324)
Post by MikeyBikey » Sat Mar 07, 2015 9:16 pm
Geoff. Looks Fantastic.
I've seen it in the flesh and it really is a testament to your excellent work. Brilliant stuff.
wes wilson
Post by wes wilson » Sun Mar 08, 2015 10:08 am
just finished the thread
just stunning diana rigg would be chuffed as im sure u are
not sure about the apple white paint though//
really loving what you have acheived such patience is a rare thing well done /wes
Has thanked: 131 times
Been thanked: 486 times
Post by Roger Pennington » Sun Mar 08, 2015 11:48 am
Looking good, Geoff (mind you, we'd expect nothing less from you! ) :D
GeoffTE
Post by GeoffTE » Sun Mar 08, 2015 7:38 pm
Aw shucks Roger, you say the nicest things :oops: The colour by BTW is Lotus Cirrus white, for some reason my photos are coming out with a green tint :?
Geoff. (5324)
wes wilson
Post by wes wilson » Sun Mar 08, 2015 7:48 pm
GeoffTE wrote:Aw shucks Roger, you say the nicest things :oops: The colour by BTW is Lotus Cirrus white, for some reason my photos are coming out with a green tint :?
was only jossing fella the car looks amazing i hope u are as happy with it as u deserve to be when u get to drive it :) :D
Coco La Blanc
Post by Coco La Blanc » Tue Mar 10, 2015 10:28 am
Geoff,
Begs a drive ---- Pleeeeeeaase ????? It looks absolutely superb ! 8) :) :) 8)
GeoffTE
Post by GeoffTE » Tue Mar 10, 2015 10:49 am
Weeeeeelllllll......I dunno Viv.....the experience might be just too much for you :lol: :lol: :lol: :wink:
Geoff. (5324)
Return to “Other Car Chat”
