differential
Jefneefs
differential
Post by Jefneefs » Tue Jul 11, 2017 4:02 am
Hi
Opened up a (spare) Sabra differential.
Wonder if it would be possible to get, as the differential case is open and the differential removed, the complete pinion unit out, complete with meshing shims and rings ands bearings.
Like it is.
It's intended to be sent to a friend with a defective differential, looks like his differential had'nt been meshed properly.
Wonder if I could hammer the complete pinion out from the inside of the differential case.
If I disassemble all the stuff it will be a lot more complicated for him to put pinion and crownwheel properly together.
Jef Neefs
Return to “Early Sabre”
