Pistons in a Mk3 Zodiac Block
Electron
Post by Electron » Sun Jan 18, 2015 12:25 pm
Hi
So it's a bit unfair me dipping in and out of the Forum once every blue moon so I did hit the "Donate" button before posting this one.
So I'm still gently collecting bits for my Zephyr Six engine - I have the triple SU manifold, carbs and exhaust manifold. The gearbox I'm using is a Mk3 with a Ford Transit gearchange !! Whilst I see the Mays heads did make it out into the wide world I had to have some chassis rails made so will have to stick with an iron one for the time being.
I have a 1300cc precrossflow engine (a funny one with a five bearing crank) and couldn't help notice the pistons bear a remarkable similarity to the Zephyr Six.
I have some brand new 85mm AE 18953 flat top precrossflow pistons sat in a box and on first inspection they would appear to fit the six.
Can anyone comment on what pistons to use in an iron headed triple SU engine please ??
Chris
Been thanked: 435 times
Re: Pistons in a Mk3 Zodiac Block
Post by Roger Pennington » Sun Jan 18, 2015 12:55 pm
Hi, good to hear the project is still on-going, and thanks for the donation :D
I'm not an expert on the straight six engine, but my dusty memory cells seem to suggest that "back in the day" Robin Rew used to use Volvo pistons in his race engine? Hopefully one of the experts will add more detail. :)
HTH
Been thanked: 101 times
Post by Oaksey » Sun Jan 18, 2015 1:20 pm
Standard P1800 pistons fit a +60 S6 block perfectly.
I haven't found any pistons that'll fit a standard block so I reused my pistons as I couldn't find any NOS ones either.
There's a couple of zodiac suppliers that might have some now or Iain Daniels may be able to help like he did with the rings for mine :)
Electron
Post by Electron » Sun Jan 18, 2015 2:03 pm
Thanks for this - standard Ford +40 pistons seem to be readily available at a similar price to the P1800s -I was wondering what a reasonable overbore is as well - looks like +60 is easy. The engine is only likely to do a thousand miles or so a year maximum ....
heathsabre
Post by heathsabre » Mon Jan 19, 2015 12:42 pm
As a matter of interest when we had our engine rebuilt (by Iain Daniels) it was found to have standard pistons and cylinder liners. We reused the standard pistons with new rings and fitted new liners. After 4 years and 10,000 miles all is well.
Tony & Jaki Heath
RSSOC Sabre Registrars
1964 Sabre Six GT
1963 Sabre Six convertible
1960 Sabra prototype
Been thanked: 64 times
Post by gtcse8 » Mon Jan 19, 2015 2:12 pm
Quick look at the Hepolite / AE bible says the part number is 19299 v1, was 17308, or 19299.
Also fitted to Transit, Corsaire, Industrial engine and Zephyr 1663cc , 2495cc 4/6 cylinder engine
Electron
Post by Electron » Tue Jan 20, 2015 8:35 pm
I thought the Transit had a V4 with chamber in pistons as did the Corsair (or a 1500 precrossflow) ?
Now looking for some Volvo pistons as +60 seems to get me to a reasonable compression ratio ...
Post by toomanysabres » Tue Jan 20, 2015 9:11 pm
Volvo std pistons part number 19749 fit a 0.060" bore. The gudgeon pin is very slightly smaller than a Ford piston. In my Sabre 4 years ago they had to use 5 bushes as one of them was already too large for reaming to size. But that's not much of an issue.
Post by gtcse8 » Tue Jan 20, 2015 11:07 pm
No, the quoted parts are for Straight Four or Six engines only.
As originally fitted to Mk3 Zodiac as the original request for info was.
Don`t know why I bother.
chrisgallacher
Has thanked: 25 times
Been thanked: 22 times
Post by chrisgallacher » Wed Jan 21, 2015 9:16 am
gtcse8 wrote: Also fitted to Transit, Corsaire, Industrial engine and Zephyr 1663cc , 2495cc 4/6 cylinder engine
These are V4 and V6 engines. I don't think the pistons fit the 2553cc straight six Zephyr engine as used in the Sabre Six/Coupe.
Chris Gallacher
RSSOC Rally Secretary
rally.secretary@rssoc.co.uk
Post by gtcse8 » Wed Jan 21, 2015 11:00 am
Sorry Chris but the Catalogue lists the part numbers as Straight 4 and 6 engines.
This must mean that Hepolite/AE who made them for Ford got it wrong.
Been thanked: 483 times
Post by philhoward » Wed Jan 21, 2015 11:07 am
Wouldn't be the first time parts catalogues got confused over the years and various re-writes..
Post by toomanysabres » Wed Jan 21, 2015 3:09 pm
V engine pistons are 93.67 dia and straight engines are 82.55 dia so no way are they the same. Also V has combustion chamber in the piston and straights are flat.
Has thanked: 112 times
Been thanked: 756 times
Post by scimjim » Wed Jan 21, 2015 3:11 pm
Could they have mixed mk3 & mk4 Zodiacs?
Post by toomanysabres » Wed Jan 21, 2015 3:13 pm
Highly likely I would think.
Return to “Early Sabre”
