Coupe heater hoses.
Been thanked: 279 times
Coupe heater hoses.
Post by AJL Electronics » Mon Oct 29, 2018 12:50 pm
Which way around do they go? Long one on the top or bottom port of the heater please?
David Tew
Has thanked: 24 times
Coupe heater hoses.
Post by David Tew » Mon Oct 29, 2018 1:00 pm
Long hose from back of pump to the top, hose from manifold to the bottom. :wink:
Has thanked: 166 times
Been thanked: 1160 times
Coupe heater hoses.
Post by scimjim » Mon Oct 29, 2018 1:45 pm
Why that way David?
I think having the “hot” hose at the top will give the heater matrix a slightly quicker warm up - but in reality I don’t think it really matters.
Has thanked: 100 times
Been thanked: 796 times
Coupe heater hoses.
Post by philhoward » Mon Oct 29, 2018 1:48 pm
Doesn't "convention" suggest the hot inlet comes in the bottom and the "cold" outlet out the top?
Coupe heater hoses.
Post by scimjim » Mon Oct 29, 2018 2:04 pm
cold water will drop down, which helps circulation and pumping hot water into the top will heat up the matrix quicker from cold.
A radiator's (hot) inlet is normally at the top?
Coupe heater hoses.
Post by philhoward » Mon Oct 29, 2018 3:02 pm
I've got something in the back of my head that suggests that automotive systems don't follow the convention for a heat exchanger but can't find anything quickly to suggest this. Almost everything automotive shows hot at the top, cold at the bottom although I did find reverse flow through the engine being used but only on "high performance" engines (hot water out from the block, cold water into the head).
Coupe heater hoses.
Post by AJL Electronics » Mon Oct 29, 2018 3:24 pm
The reason for asking is that the hose to the pump will be grazing the top of the engine if it feeds the bottom as expected.
Coupe heater hoses.
Post by scimjim » Mon Oct 29, 2018 3:32 pm
parts list shows it as David said - with clips for the top hose
coupe heater.jpg (133.01 KiB) Viewed 1715 times
roymck
Has thanked: 15 times
Been thanked: 29 times
Coupe heater hoses.
Post by roymck » Mon Oct 29, 2018 3:47 pm
Can straight hoses be used is there room , hose 19 has a particularly tight bend on it . I guess original hoses are NLA
David Tew
Coupe heater hoses.
Post by David Tew » Mon Oct 29, 2018 4:06 pm
I used straight silicon hoses with couplers and 90-degree bends at the matrix. Where pipe 20 wraps around the bulkhead I bent a piece of 15mm copper pipe fixed in place by the original clips so the run from the pump is also straight.
Return to “Coupé”
