Coupe boot lock
roymck
Has thanked: 15 times
Been thanked: 23 times
Coupe boot lock
Post by roymck » Sun Oct 14, 2018 6:50 pm
Simple question ,if a Coupe bootlock is locked is the key verticle or horizontal when locked ?
Been thanked: 90 times
Coupe boot lock
Post by Coupe Racing » Sun Oct 14, 2018 7:03 pm
Vertical from memory but wait for others to confirm
Been thanked: 74 times
Coupe boot lock
Post by DARK STAR » Sun Oct 14, 2018 8:51 pm
Again from memory (the car is in a lock-up in town) both are vertical, the key turns 180º ...
Been thanked: 117 times
Coupe boot lock
Post by ScimmyMike » Sun Oct 14, 2018 11:04 pm
Agree with Chris on that point
roymck
Coupe boot lock
Post by roymck » Mon Oct 15, 2018 8:22 am
That’s a problem . So the guy I bought it from said he filled the boot with spares and he locked it .
Does the button push in wether the lock is locked or unlocked?
I can put a key in the lock but can’t turn it but the button pushes in .
Is it possible the load has shifted in the boot and is stopping me from turning the key to unlock it ?
Going away for a few days to sprayed WD40 in the lock and will look at it at the weekend.
Coupe boot lock
Post by Coupe Racing » Mon Oct 15, 2018 8:46 am
Again from memory
When it's locked the button does not push in
The lock is pretty well protected by a plate so parts movement should not be an issue
However the button plunger no longer actiing on the catch is the likely problem
There was a discussion about this very recently
Coupe boot lock
Post by DARK STAR » Mon Oct 15, 2018 12:11 pm
Agreed.
Sorry Roy :(
mn757
Been thanked: 11 times
Coupe boot lock
Post by mn757 » Mon Oct 15, 2018 12:21 pm
Any wear in the plate that the plunger presses on will result in the two parts not aligning. You can drill a tiny hole in the rear panel, insert a small pin and open the boot that way if worst comes to worse. There is a photo on here somewhere showing where to drill. I obtained a NOS mechanism from a guy in Malta. IIRC it's from a MK3 Ford Zodiac but my memory may be failing me.
1965 Scimitar GT SE4
1976 Scimitar GTE SE6
1985 SS1 1300 5 Speed
also...
Has thanked: 131 times
Been thanked: 486 times
Coupe boot lock
Post by Roger Pennington » Mon Oct 15, 2018 12:59 pm
roymck
Coupe boot lock
Post by roymck » Mon Oct 15, 2018 4:18 pm
If the button does not push in when it’s locked then that narrows down the problem then .
roymck
Coupe boot lock
Post by roymck » Thu Oct 18, 2018 6:07 pm
Well had another look at it today and before I drilll out he lock any other thoughts on it .
1/ The button pushes in but the boot remains shut.
2/ I cannot turn the key in the barrel so if it is locked I can not unlock it , but the button pushes in so is it locked or unlocked?
3/ is it possible there is something in the boot stopping me from turning the lock with the key
4/How much explosive do I need to blow it open :lol:
Coupe boot lock
Post by DARK STAR » Thu Oct 18, 2018 6:57 pm
Just a thought, you've just bought the car, have you ever opened the boot?
If not, are you sure it's the right key?
If the button pushes in it should already be unlocked, but you never know ...
Coupe boot lock
Post by DARK STAR » Thu Oct 18, 2018 7:02 pm
Just realised, this is a new car for the photo register!
Matt lists it in Northern Ireland in 1974, no news since :shock:
Coupe boot lock
Post by Coupe Racing » Thu Oct 18, 2018 7:19 pm
This has been answered already
1 - ok
2 - its unlocked if the button pushes in
3 - no - its protected by a plate
4. - see the thread link as a member gained access in a less destructive manner
roymck
Coupe boot lock
Post by roymck » Thu Oct 18, 2018 7:55 pm
1 - ok
4. - see the thread link as a member gained access in a less destructive manner[/quote]
Yes I know just thought somebody may have had any other thoughts . Looks like I am drilling holes tomorrow
Return to “Coupé”
