Coupé engine bay photos required.
Been thanked: 298 times
Post by AJL Electronics » Sat Sep 08, 2018 4:46 pm
Restoring a coupé SE4a under the bonnet and would be interested to see how it should look in terms of component placement. Modified would also be interesting.
Been thanked: 427 times
Post by peter freeman » Sat Sep 08, 2018 4:53 pm
here's a start for you
Post by peter freeman » Sat Sep 08, 2018 4:56 pm
1st photo was 2016 this one is 2017 - not much changed.
Dcrosby13
Has thanked: 41 times
Been thanked: 135 times
Post by Dcrosby13 » Sat Sep 08, 2018 5:02 pm
From this.........
ImageWhatsApp Image 2018-04-11 at 19.55.40(4) by Darryl Crosby, on Flickr
To this.........
ImageIMG_20180510_160411 by Darryl Crosby, on Flickr
ImageIMG_20180506_201233 by Darryl Crosby, on Flickr
I break stuff...... :w
briankenyon
Post by briankenyon » Sat Sep 08, 2018 5:07 pm
briankenyon
Post by briankenyon » Sat Sep 08, 2018 5:09 pm
Post by Roger Pennington » Tue Sep 11, 2018 12:54 am
"The Rat":
Post by AJL Electronics » Tue Sep 11, 2018 1:57 pm
Thanks all, most useful. This engine bay is largely original so keen to see where the alternator regulator and fusebox is as standard. The wiring has been bodged a bit on this one and I have to sort it out!
Post by peter freeman » Tue Sep 11, 2018 3:34 pm
Most Coupés now have alternators with internal regulators - originally mine had a external regulator where the lumenition module now resides.
rebel alliance
Been thanked: 97 times
Post by rebel alliance » Tue Sep 11, 2018 3:35 pm
Has thanked: 178 times
Been thanked: 1226 times
Post by scimjim » Tue Sep 11, 2018 4:06 pm
Pic of mine taken by PO
Chet
Post by Chet » Mon Sep 17, 2018 6:35 am
These photos from my SE4a before dismantling. Wiring loom not all original, but I think placement of components is. Both are of near side. Top photo shows relays etc. As far as I can work out from wiring colours (the electrics were dead) the relays from left are headlamp flash and horn on bulkhead shelf, ignition on front of bulkhead, and heated rear window on side behind wiper motor. Instrument voltage stabilizer is just out of sight on side of tunnel below and slightly behind headlamp flasher relay. Bottom photo shows original fuse box
John
N-S 2.JPG (237.89 KiB) Viewed 2589 times
mermar74
Post by mermar74 » Mon Sep 17, 2018 8:38 am
Interested to know more about this Daimler 2.5 litre Daimler powered Coupe; is it still around and is more known about it? Also any more pictures of this car?
Victor Pace
Been thanked: 842 times
Post by philhoward » Mon Sep 17, 2018 9:08 am
Post by AJL Electronics » Mon Sep 17, 2018 9:11 am
Body to turret bolts... Should they be 5/16" UNF or 3/8" please?
Return to “Coupé”
