Aluminium hose
briankenyon
Aluminium hose
Post by briankenyon » Tue Jul 31, 2018 8:33 am
Would anyone be interested ??
Top and bottom hose made out of aluminium (polished)
Maybe able to get them made if enough interest
At £50 A pair your thoughts would be appreciated
Has thanked: 32 times
Been thanked: 132 times
Aluminium hose
Post by Coupe Racing » Tue Jul 31, 2018 9:09 am
Will they need to be coated internally if used with an iron block ?
briankenyon
Aluminium hose
Post by briankenyon » Tue Jul 31, 2018 10:29 am
Arrrgh
Steve never thought of that, how would they need to be coated ??
briankenyon
Aluminium hose
Post by briankenyon » Tue Jul 31, 2018 10:34 am
Are these new all Ili radiators coated internally ??
briankenyon
Aluminium hose
Post by briankenyon » Tue Jul 31, 2018 11:09 am
Just a thought isnt the water pump and thermostate housing made of aluminium are they coated internally.
I'm thinking,
A good mixture of blue antifreeze should solve any problems :w :w
Been thanked: 842 times
Aluminium hose
Post by philhoward » Tue Jul 31, 2018 11:14 am
As long as your coolant is suitable (i.e. non-OAT, but includes a corrosion inhibitor) and up to scratch (changed every 2 years or so) there shouldn't be an issue? They're not directly connected, so any connection would be through the coolant, hence if it's good stuff (Bluecol or Prestone, or similar), there shouldn't be an electrolytic reaction?
I suspect Anodising would be sufficient should a "coating" be needed?
Been thanked: 117 times
Aluminium hose
Post by DARK STAR » Tue Jul 31, 2018 6:46 pm
As Phil says, if there is no metal-to-metal contact there shouldn't be a problem.
If there is contact (e.g. Daimler V8 heads to block) no amount of antifreeze will prevent corrosion.
Fernox or similar central heating treatment will though ;-)
briankenyon
Aluminium hose
Post by briankenyon » Tue Jul 31, 2018 7:41 pm
No metal to metal contact is possible when using normal rubber hoses from pump to pipe, pipe to radiator etc
Return to “Coupé”
