Indicator stalk
backpain
Has thanked: 26 times
Indicator stalk
Post by backpain » Thu Apr 12, 2018 8:08 am
Sorting my indicators out ,,should there be a spring or something behind the large copper contact in pic .to push it onto the left and right indicator contacts
Miss Moneypenny Coupe
Been thanked: 74 times
Indicator stalk
Post by DARK STAR » Thu Apr 12, 2018 5:40 pm
I think I have one of those in stock.
I'll have a look tomorrow.
The one on the car, however, is off a 5a ;-)
backpain
Indicator stalk
Post by backpain » Thu Apr 12, 2018 7:06 pm
A 5a well that's interesting thanks fingers crossed john
guybetts
Indicator stalk
Post by guybetts » Thu Apr 12, 2018 10:42 pm
Yes there is a spring under the copper contact.
Guy
GTC Registrar
Been thanked: 117 times
Indicator stalk
Post by ScimmyMike » Fri Apr 13, 2018 2:03 pm
If you need a replacement switch I've got several in my spares stash could part with one to help you out
Been thanked: 90 times
Indicator stalk
Post by Coupe Racing » Fri Apr 13, 2018 4:25 pm
I have a Coupe spare too with the knurled knob at the end
backpain
Indicator stalk
Post by backpain » Sat Apr 14, 2018 7:19 am
Hi Any luck or should I go to the other offers thanks john
Indicator stalk
Post by DARK STAR » Sat Apr 14, 2018 11:54 am
I've been through two crates without luck :|
I would go to the others, thanks for waiting!
backpain
Indicator stalk
Post by backpain » Sat Apr 14, 2018 12:43 pm
Hi I only need the small Spring but happy to take the whole thing Please advise what you want for it and postage and I will PayPal you. John. Thanks and thank you Dark star
Indicator stalk
Post by DARK STAR » Sun Apr 15, 2018 7:44 pm
Found mine while looking for something else (which I didn't find)
And it doesn't look anything like yours, could it be a dip-switch?
The mechanism is fine, complete with spring, but one of the wires has disappeared completely.
Probably why I changed it.
It should be possible to solder a new wire in, I'll have a go when I have time 8)
If I don't misplace it again ...
backpain
Indicator stalk
Post by backpain » Sun Apr 15, 2018 9:06 pm
My dip switch is on the floor close to clutch :)
Indicator stalk
Post by ScimmyMike » Sun Apr 15, 2018 11:02 pm
Will dig it out and price postage for you John and let you know via PM
Indicator stalk
Post by DARK STAR » Mon Apr 16, 2018 6:45 am
I'm sure my Coupé had two stalks originally (well, when I bought it 30 years ago).
Also that it didn't have a floor dip-switch.
I don't remember where the horn push was.
Current configuration is horn and indicators on single column stalk (SE5a) and dip on old overdrive switch.
What year is your car, mine is 1968 - 50th birthday next month!
backpain
Indicator stalk
Post by backpain » Mon Apr 16, 2018 8:03 am
Mine first reg 2/8/67 and has 2 stalks,,,, horn on left with indicators on right pull back to flash. Do you think this is original
Been thanked: 562 times
Indicator stalk
Post by philhoward » Mon Apr 16, 2018 8:18 am
I believe so - the horn did have its own stalk. On the S6 coupe (or might be the Sabre) I think it was a "press any way you want" switch for the horn (also known as a trembler switch) - not sure if that was the same for the V6 as well?
Return to “Coupé”
