Carpets
Been thanked: 57 times
Carpets
Post by Nick » Sun Feb 04, 2018 1:27 pm
Mine are looking pretty tatty so am thinking of changing. Does anyone do a set? Alternatively can a 5 set be easily converted? Otherwise I can cut to fit.
Any experience of sound deadening/heat insulation under the carpets.?
1969SE5
Carpets
Post by 1969SE5 » Sun Feb 04, 2018 7:34 pm
i would be interested to hear about sound deadening and underlay myself.
just about to fit new carpets following respray, all advice welcomed.
cheers
Carpets
Post by Nick » Tue Feb 06, 2018 9:49 am
bump
Been thanked: 113 times
Carpets
Post by ScimmyMike » Tue Feb 06, 2018 12:24 pm
Nick, currently going through the same process and will be using under the car over the exhausts Thermoguard FR shiny side towards the heat they told me hence the under car fitment, then inside I'm using Dodomat inside the car with the thermoguard below over the transmission tunnel and heater box area as well as using the dodomat to replace the crumbly insulation in the dash area, on my white coupe I also placed a layer of genric wool type over the behind dash area which I found made a big difference.
When I get to do the carpets I'm intending making up a set of patterns for members to borrow.
Carpets
Post by Nick » Tue Feb 06, 2018 6:14 pm
Mike,
Thanks for the feedback, use of your patterns in due course would be much appreciated
guybetts
Has thanked: 24 times
Carpets
Post by guybetts » Tue Feb 06, 2018 6:34 pm
Mike, I have sent you an email on this subject :)
GTC Registrar
Carpets
Post by Oaksey » Tue Feb 06, 2018 6:49 pm
Keep in mind that S6 and V6 are drastically different
Carpets
Post by ScimmyMike » Wed Feb 07, 2018 4:48 pm
I raised a question with Dodomat here's their reply:
Hi Mike,
The best product to use for noise reduction would be the Dodo Sound Stopper Lite. This contains the important MLV barrier which can block the full range of frequencies. This is sandwiched between 2 layers of acoustic foam to absorb the mid-high range frequencies.
This product is flexible and can be easily applied all over (except the roof) using a contact spray adhesive, such as Dodo Adhesive. Focus on the floor, footwells, transmission tunnel and boot area to reduce the noises you describe.
A 100% coverage will also help with heat transfer.
https://www.deadening.co.uk/products/do ... opper-lite
https://www.deadening.co.uk/products/do ... p-adhesive
If this is overbudget, then I would suggest Dodo Pro Barrier (£5 per sheet less) or the MLV barrier on it's own.
Kind Regards,
Matt,
Dodo Mat
Carpets
Post by ScimmyMike » Wed Feb 07, 2018 4:49 pm
Where to Guy, nothing has appeared?
guybetts
Carpets
Post by guybetts » Wed Feb 07, 2018 7:39 pm
Via the email facility in this forum. I'll try a PM but had problems with it in the past.
Guy
GTC Registrar
guybetts
Carpets
Post by guybetts » Wed Feb 07, 2018 7:45 pm
Mike, PM sent fingers crossed :)
GTC Registrar
Been thanked: 840 times
Carpets
Post by scimjim » Wed Feb 07, 2018 7:47 pm
Test email and PM sent Mike
Return to “Coupé”
