Coupe Gearbox swop.
Coupe Gearbox swop.
Post by stevmale » Thu Oct 26, 2017 6:42 pm
I am hoping to start some local sprinting next year with my Coupe.
The original O/D box is fitted and performs ok.
But I am considering either :
Removing the O/D and replacing it with a 4 speed shaft & tail housing from a Zephyr 4 speed box
Installing a Type 5 with a bell housing that allow a hydraulic clutch mechanism.
Does anybody know is this easy route or even possible .
or do I have to fit a type 5 with a cable + pedal etc.
Coupe underside 1.jpg (151.55 KiB) Viewed 540 times
Currently - SE6 3.4 for Sunday morning's + Coupe for the track .
Previously - 4 x SE5's
Coupe Gearbox swop.
Post by efi_sprintgte » Thu Oct 26, 2017 9:02 pm
Short nose type 5 with correct bellhousing is hydraulic
Been thanked: 254 times
Coupe Gearbox swop.
Post by peter freeman » Thu Oct 26, 2017 10:03 pm
Personally I would stick with what you have got - it will enable you to change gear quicker by use of the OD switch - clutch less. Our local sprint man has his set up so it works on all forward gears.
Been thanked: 49 times
Coupe Gearbox swop.
Post by Nick » Thu Oct 26, 2017 11:03 pm
If you change the housing, e,g, type 9 that strictly puts you in mod sport. Provided selector bushes etc. Are ok the overdrive box is ok. On some tracks (eg aintree) overdrive third is useful. I would not convert the overdrive to work on second as this may be too much for it.
1968 Coupe, MR2 and Beemer 3 series
Has thanked: 36 times
Been thanked: 446 times
Coupe Gearbox swop.
Post by philhoward » Fri Oct 27, 2017 7:54 am
I can only assume that a change of gearbox is only permitted (to not fall foul of the rules) to another type as fitted to the same car type? In the case of a V6 Coupe, then it means only the 2-rod overdrive gearbox (although if a Scimitar GT, then you could fit the ZF as used in some straight 6 cars?) but in a 5a, you could use the 2-rod, type 5 or Type F (3 rod box)? If it applied to "Scimitar" then that doesn't include the Type 9 being used in the Middlebridge?
Has thanked: 109 times
Been thanked: 691 times
Coupe Gearbox swop.
Post by scimjim » Fri Oct 27, 2017 9:09 am
That’s how Blue Thunder used a 2.9 :-)
For the box though,
Roadgoing Series Production Cars.
(a) The gearbox and differential casing must be externally identifiable as that fitted to the original model or specified option and remain in their original position.
Modified Series Production Cars and Modified Specialist Production Cars
12.7.1. Transmission layout to remain as original.
12.7.2. Gearbox and differential are free.
Return to “Coupé”
