Speedo cable securing bracket
backpain
Has thanked: 26 times
Post by backpain » Thu Oct 26, 2017 9:56 am
I am putting my coupe back together and I cannot find the bracket that secures the speedo cable to gearbox is it the same as a 5a Y shape with bolt hole if it is I think I need a replacement cheers john
Miss Moneypenny Coupe
Has thanked: 34 times
Been thanked: 72 times
Post by b.c.flat hat » Thu Oct 26, 2017 11:42 am
Mine's a V6, two rod box with o/d and has the bent Y with bolt. Best o' luck, Crusty.
backpain
Post by backpain » Thu Oct 26, 2017 3:15 pm
Yep mines the same thanks Crusty ,,found it ,!!! :D :D
Return to “Coupé”
