coupe clock
pjkpjk
coupe clock
Post by pjkpjk » Sun Jun 18, 2017 7:44 pm
Hi, I`ve recently acquired Geoff Coopers rally`d straight six Coupe.Two queries if any one could help? Firstly the clutch pedal seems extremely heavy,and slow to engage/disengage? is this normal?the gearbox works well,and it can be driven, but just doesn't seem right.Secondly the dash is missing an instrument, between the fuel guage,and ammeter.Is this a clock? if so are they available,and where should I look for one? thanks Peter
Been thanked: 283 times
Re: coupe clock
Post by peter freeman » Sun Jun 18, 2017 8:03 pm
Yes the clock is between the fuel and ammeter gauges - quite where you can get one I don't know - they are larger than normal. As to the clutch I have just put a new one in my Coupe and it is heavy - more noticeable as it was the pressure plate that had failed and it was weaker than norm. I cannot say mine is slow to operate though - perhaps your slave cyl needs some lubrication - try a spray of silicone oil.
Been thanked: 94 times
Re: coupe clock
Post by ScimmyMike » Sun Jun 18, 2017 8:21 pm
I do have a non working coupe clock if you want to fill the hole
pjkpjk
Re: coupe clock
Post by pjkpjk » Sun Jun 18, 2017 8:34 pm
Thanks for that, I`ll try silicone, is there a makers name on the clock? thanks Peter
Re: coupe clock
Post by peter freeman » Sun Jun 18, 2017 10:30 pm
I will have a look tomorrow to see if there's a makers name - its getting dark out there now.
Re: coupe clock
Post by ScimmyMike » Mon Jun 19, 2017 10:12 am
pjkpjk wrote:Thanks for that, I`ll try silicone, is there a makers name on the clock? thanks Peter
Pretty sure it's usually a smiths item
Gillsfan
Re: coupe clock
Post by Gillsfan » Mon Jun 19, 2017 11:16 am
Is the clock you are after the slightly larger than the other games one as per this photo.
If so I may have one, I'll have to check it works.
1969 SE 5 Manual O/D Rat Rod
Re: coupe clock
Post by peter freeman » Mon Jun 19, 2017 11:28 am
The make on my clock is KIEZLE -there will be other makes of course.
Gillsfan
Re: coupe clock
Post by Gillsfan » Mon Jun 19, 2017 11:32 am
I'm fairly sure the one in that Rod and the spare I have are both smiths, but the one in 8 ball is KIEZLE.
Has thanked: 113 times
Been thanked: 750 times
Re: coupe clock
Post by scimjim » Mon Jun 19, 2017 2:23 pm
I thought 8ball had a Smiths, or possibly Jaeger but not Kienzle? Will check next weekend.
MarkHawkins
Re: coupe clock
Post by MarkHawkins » Mon Jun 19, 2017 3:17 pm
I think it's a Smiths in HBL 725G also (car currently at club storage). HBL has a Charge / Discharge meter (amps?) rather than a volt meter whose accuracy has improved greatly since I removed the radio speaker.
Custodian of :
1968 '4b Coupe HBL 725G
ex 1974 '5a auto - VLN 826M
Been thanked: 69 times
Re: coupe clock
Post by Coupe Racing » Mon Jun 19, 2017 7:49 pm
Ive only ever seen Smiths - but anything could be fitted over such a long period of time
Gillsfan
Re: coupe clock
Post by Gillsfan » Mon Jun 19, 2017 8:23 pm
This is the spare clock I have.
I've connected it up and it ticks, I've left it connected to see if it keeps time.
Re: coupe clock
Post by scimjim » Mon Jun 19, 2017 8:55 pm
Gillsfan wrote:I'm fairly sure the one in that Rod and the spare I have are both smiths, but the one in 8 ball is KIEZLE.
I don't know how but you were right :mrgreen:
Gillsfan
Re: coupe clock
Post by Gillsfan » Mon Jun 19, 2017 9:05 pm
8) 8) 8) 8)
I remember looking at it to check the make when I first got Rat Rod, because Rat Rod didn't have one. Although I have no recollection how I ended up with 2.
Return to “Coupé”
