Gearbox out
Been thanked: 41 times
Gearbox out
Post by Nick » Sun Apr 16, 2017 3:50 pm
I have my Coupe booked in with my local Classic Car shop for Mot and some work.
I have asked them to look at a gearbox leak, and sloppy linkages (I have the bush set from QRG)
In practical terms, what can be done with the box in situ. If it needs to come out ,how long?
1968 Coupe, MR2 and Beemer 3 series
RSSOC Championship Co-ordinator
Been thanked: 252 times
Re: Gearbox out
Post by peter freeman » Sun Apr 16, 2017 3:55 pm
Depends on what GB is fitted - the very early ones fitted to the S6 were as bad as the 5 and 6 box - the two rail box is best and comes off the bell housing so its easier to get out. Prop shaft removed - six bolts to undo and the GB mount to remove - gear stick electrics etc and out it comes - couple of hours depending if you have the car on a lift or on the ground.
Re: Gearbox out
Post by Nick » Mon Apr 17, 2017 10:37 am
Thanks Peter
2 rod overdrive on a V6
Has thanked: 31 times
Been thanked: 66 times
Re: Gearbox out
Post by Oldconn » Mon Apr 17, 2017 10:42 am
Even easier if you disconnect the exhaust and radiator pipes, then tilt the engine backwards a few degrees. Carb & linkage also
Return to “Coupé”
