Improving hand brake - ideas?
MarkHawkins
Re: Improving hand brake - ideas?
Post by MarkHawkins » Tue May 02, 2017 5:27 pm
An update :
So far we have replaced the cable, the wheel cylinders, the shoes, welded and flattened the small groves in the back plates, reassembled with copper grease on the sliding wheel cylinders. The hand brake holds the car on a hill and locks the rear wheels on gravel but not on good tarmac - still not enough to make the 25%
The new handbrake cable is greased and I don't believe I have it running through too tight an angle.
Custodian of :
1968 '4b Coupe HBL 725G
ex 1974 '5a auto - VLN 826M
Been thanked: 285 times
Post by peter freeman » Tue May 02, 2017 5:41 pm
That only leaves the drums and connection point the the bottom of the handbrake lever. It was a mod to drill the Coupe lever to increase the pulling power IIRC.
Post by peter freeman » Tue May 02, 2017 5:55 pm
Holes to adjust pulling power - knew I had a drawing somewhere. Fit closer to pivot point to increase movement/pulling power.
MarkHawkins
Post by MarkHawkins » Thu May 04, 2017 9:06 pm
Are coupe handbrakes levers the same as those on later more numerous cars?
Custodian of :
Has thanked: 112 times
Been thanked: 756 times
Post by scimjim » Thu May 04, 2017 9:18 pm
I think the straight six have fly off hand brakes? What we really need to know is if a small sports handbrake will fit a v6 coupe?
Been thanked: 53 times
Post by DARK STAR » Thu May 04, 2017 9:22 pm
V6's have fly-off handbrakes too, at least mine has ...
Been thanked: 483 times
Post by philhoward » Thu May 04, 2017 9:31 pm
If a 5/a one will fit, then a small sports one will.
I thought that picture from Peter was a Coupe one - it's a 5a one.
MarkHawkins
Post by MarkHawkins » Thu May 04, 2017 9:48 pm
We don't have a turnbuckle at present - just the two steel strips so moving the pivot point may be more problematic.. A 5a cable was fitted - slightly longer than than the previous cable but as both ends of the outer cable are fixed, should that be a problem? When I viewed the freshly built up V6 coupe chassis at QRG the other month it all looked so clean and simple ...
Custodian of :
Post by peter freeman » Thu May 04, 2017 9:52 pm
Yes its a 5A one but drilling the hole is a mod to the Coupes as well. I think Chris that the 4B's have the fly off handbrake - my 4A does not - don't know about the other 4's.
MarkHawkins
Post by MarkHawkins » Thu May 04, 2017 10:13 pm
In operation HBL's hand brake feels just like that on ALJ - there is a ratchet mechanism and you can partially apply or release the hand brake so I don't think its 'fly off'.
Custodian of :
Been thanked: 435 times
Post by Roger Pennington » Thu May 04, 2017 11:28 pm
There's a thread about Coupe handbrakes (and fly-offs in particular), here in the members' archive, which might be some help?
Post by scimjim » Fri May 05, 2017 8:44 am
So it looks like the coupes with a fly-off handbrake have a bracket from the chassis but do the coupes with a "normal" handbrake have that bracket? If not, I expect it could be a straight swap for a later handbrake?
Post by DARK STAR » Sat May 06, 2017 5:51 pm
Just thought of that myself, I was puzzled why mine was so different - and I had to shorten the SE5a cable outer by 3 cm.
MarkHawkins
Post by MarkHawkins » Sun May 07, 2017 9:22 pm
Comparing the exiting hand brake and the 'new' SS1 hand brake they appear the same apart from the orientation of the fitting holes. On the Coupe the are alternate sides but the SS1 brake has both holes on one side. Would it be feasible to use localised heat to bend the mount to the other side, or possibly but cut and weld it?
Custodian of :
Post by scimjim » Sun May 07, 2017 10:19 pm
I expect it would bend with some heat.
Return to “Coupé”
