Lights/Noise
peterbradbury
Lights/Noise
Post by peterbradbury » Sat Sep 12, 2015 11:20 pm
Hi everyone,
So I drove the Coupe at night for the 1st time yesterday and came across this interesting problem. As soon as I turned the lights on (sidelights or headlights) there is a very irritating noise, like an electric buzzer. When the car is not moving there is no noise, however when its moving or there is any input into the steering it starts again. I can only guess that something is shorting somewhere? Any suggestions welcome!
Peter
60 Austin Seven, 67 Mini Moke, 80 Mini Pick Up, 96 Mini Equinox, 68 Coupe, 87 SS1 1800Ti
Joe.
Been thanked: 27 times
Re: Lights/Noise
Post by Joe. » Sun Sep 13, 2015 12:42 am
Sounds like it could be the relays, I'd start with those before looking for a short.
tony.idle
Been thanked: 55 times
Re: Lights/Noise
Post by tony.idle » Sun Sep 13, 2015 6:32 am
Try disconnecting the horn for a start.
Tony
RSSOC 2332 since 1981
Has thanked: 57 times
Been thanked: 83 times
Re: Lights/Noise
Post by Oldconn » Sun Sep 13, 2015 8:58 am
Relays a distinct possibility. Peter Freeman put me onto this when I had the same on my car. Look for a faulty earth connection to one relay.
peterbradbury
Re: Lights/Noise
Post by peterbradbury » Sun Sep 13, 2015 10:05 pm
Great! Can start looking into that
peterbradbury
Re: Lights/Noise
Post by peterbradbury » Sun Jan 03, 2016 10:24 pm
I've had the top of the dash off and a little poke around but haven't got anywhere yet!
This is the noise I'm getting. I found to relays, but it doesn't seem to be either of then. Has anyone got any other suggestions?
Peter
Been thanked: 854 times
Re: Lights/Noise
Post by scimjim » Sun Jan 03, 2016 10:32 pm
You haven't got an old "lights on" buzzer behind there have you? If it's lost the ignition feed (or interior light switch feed on some), it will buzz as soon as the lights are turned on?
Been thanked: 473 times
Re: Lights/Noise
Post by Roger Pennington » Sun Jan 03, 2016 11:30 pm
It does sound much more like a buzzer than I'd expected. Could you try moving your phone about behind the dash while recording, to see if it gets louder in one direction or another?
peterbradbury
Re: Lights/Noise
Post by peterbradbury » Mon Jan 04, 2016 8:57 pm
scimjim wrote:You haven't got an old "lights on" buzzer behind there have you? If it's lost the ignition feed (or interior light switch feed on some), it will buzz as soon as the lights are turned on?
Interesting, I had a problem with the interior light not going out at all just before the international last year so we just removed it. I'll put it back in and see if this has an effect!
Roger Pennington wrote:It does sound much more like a buzzer than I'd expected. Could you try moving your phone about behind the dash while recording, to see if it gets louder in one direction or another?
The noise seemed to be fairly central/just to the drivers side.
Thank you
Has thanked: 118 times
Been thanked: 21 times
Re: Lights/Noise
Post by willholderogri » Mon Jan 04, 2016 9:03 pm
indicator relay will do this
Been thanked: 326 times
Re: Lights/Noise
Post by peter freeman » Mon Jan 04, 2016 9:04 pm
Something to do with the gauge lights ? if you still have the gauge on off light switch try it off
Been thanked: 73 times
Re: Lights/Noise
Post by DARK STAR » Fri Jan 08, 2016 7:35 pm
Not that I have any ideas at the moment, to clarify:
Buzzer sounds when lights on AND
when the car is moving OR when steering turns even if not moving.
Does it do the same ignition on and off?
peterbradbury
Re: Lights/Noise
Post by peterbradbury » Sun Jan 10, 2016 9:25 pm
Thank you everyone for the suggestions and help! The problem is now solved. It was a warning buzzer for the lights being on and the answer was getting the interior light working. Just got to sort the switch on the drivers side door as the light has a habit of staying on!
Re: Lights/Noise
Post by Roger Pennington » Sun Jan 10, 2016 10:06 pm
Excellent! - glad you got to the bottom of the problem :D
Re: Lights/Noise
Post by peter freeman » Mon Jan 11, 2016 5:31 pm
The buzzer obviously is a retro fit which is why none of us got it right.
Return to “Coupé”
