Coupe Register
- toomanysabres
- RIP
- Has thanked: 14 times
- Been thanked: 88 times
Re: Coupe Register
Could the SA prefix be one of those South African engines that mermar has had all the trouble with.
- scimjim
- RSSOC Member
- Has thanked: 116 times
- Been thanked: 853 times
Re: Coupe Register
Engines were consecutive but with 2 models being produced consecutively they got a bit mixed up. The first SE5s had SC9xx engines IIRC.
- scimjim
- RSSOC Member
Re: Coupe Register
SC is Reliants engine serial number prefix - they allocated the numbers not Ford.toomanysabres wrote:Could the SA prefix be one of those South African engines that mermar has had all the trouble with.
Re: Coupe Register
thanks for the replys
the production date or paint code makes sense ,
I assume there is similar #s stamped on other plates ?
another question is ---- there is an alloy plate riveted near the bonnet catch ( on the body) it is about 3"x 1" , this plate is blank , as in nothing is visible , what was on this plate ?? my guess is a warning radiator cap may be ??
some one will know
change of season in Adelaide --- getting colder , opposite to you in the UK
cheers
harky
some one will know
cheers
harky
- RSSOC Member
- Has thanked: 64 times
- Been thanked: 18 times
Re: Coupe Register
Hi Harky
Yes this plate refers to cooling system and also informs you that-"Bluecol Anti-freeze must be used"
phil
phil
- Has thanked: 1 time
Re: Coupe Register
Hi, I am looking for a replacement radiator caution plate any ideas where I might get one?
David franklin
David franklin
Re: Coupe Register
Hi Matt
Just bought a Coupe on ebay Jim King says you've not had chassis or reg numbers off owner, will do my best to secure for both cars when pick collect !
PS Silverstone swung it for me first time next to one instead of pics.... Thought Wow ! Got to have one
Will Keep in touch
Start new thread for resto
If at Curbs will catch up
Phil
Will Keep in touch
Phil
- DARK STAR
- RSSOC Member
- Been thanked: 72 times
- Contact:
Re: Coupe Register
This one?
Looks sad ...
Looks sad ...
- Attachments
- 002-43.jpg (99.23 KiB) Viewed 3136 times
- scimjim
- RSSOC Member
Re: Coupe Register
Is that another one behind it?
- toomanysabres
- RIP
Re: Coupe Register
Usual story first start stripping the paint - realise the enormity of the restoration - give up.DARK STAR wrote:This one?
Looks sad ...
- RSSOC Member
- Has thanked: 26 times
- Been thanked: 15 times
Re: Coupe Register
From the colour, the shed and the shrubbery, I think those two are in Surrey or thereabouts. They surface from time in these types of articles but the guy wont sell them or his other classics, all in similar state. I think they were on the forum within the last year, so am sure Roger or Jim our resident thread hounds might find them!
- Roger Pennington
- RSSOC Member
- Has thanked: 125 times
- Been thanked: 472 times
Re: Coupe Register
Thread hounds, indeed?!
I resemble that remark!
However, there's nothing like a challenge - try this thread 'ere for a start!
- scimjim
- RSSOC Member
Re: Coupe Register
Thought I recognised it but was on my way out, so couldn't investigate
- RSSOC Member
