SS1 diff mount help
MartinSS1
SS1 diff mount help
Post by MartinSS1 » Fri Apr 05, 2019 7:10 pm
Hi Mark. I'm near Banbury, Oxfordshire.
Do you have a picture of a GTE bush?
Been thanked: 106 times
SS1 diff mount help
Post by swoakes » Fri Apr 05, 2019 7:14 pm
All the hard copy history went when I sold the car so all I have is a few digital photos. If you PM me your email address I'll send what I have.
It's a shame but I never started a project thread on that car on here so remember very little. It was an Ebay purchase and the NS rear trailing arm failed in a spectacular way one day. Other than that sorry..... :roll: :lol:
Has thanked: 33 times
Been thanked: 157 times
SS1 diff mount help
Post by gtcse8 » Fri Apr 05, 2019 7:29 pm
See pictures above?
How they got there before I took them beats me LOL.
EX SST 1800Ti
MartinSS1
SS1 diff mount help
Post by MartinSS1 » Fri Apr 05, 2019 8:49 pm
Perfect, thanks.
mikeh
SS1 diff mount help
Post by mikeh » Sat Apr 06, 2019 8:07 pm
The rear diff rubber mounts were off a rover p6 from memory. If you have the old Bush get the number off it and Google it. They aren't easy to get hold of and were about £50 each. They occasionally pop up on eBay.
Mike
Has thanked: 164 times
Been thanked: 551 times
SS1 diff mount help
Post by Roger Pennington » Tue Apr 09, 2019 8:30 pm
I've changed a number of Se6a column bushes and a couple of SS1 ones, and I'd say they look identical to my eyes. I've never needed to put a micrometer on them to compare though.
MartinSS1
SS1 diff mount help
Post by MartinSS1 » Tue Apr 23, 2019 12:47 pm
Just you try and break again!
MartinSS1
SS1 diff mount help
Post by MartinSS1 » Tue Apr 23, 2019 1:00 pm
And from above
Has thanked: 152 times
Been thanked: 1038 times
SS1 diff mount help
Post by scimjim » Tue Apr 23, 2019 1:02 pm
Nice welding - I have 2 chassis here that need sills if you find yourself at a loose end :D
MartinSS1
SS1 diff mount help
Post by MartinSS1 » Tue Apr 23, 2019 1:11 pm
Thanks :) The sill was a pain in the behind! I'm not sure I don't doing another for a while! Worst bit was cutting off the previously repaired A post. Must have cost a fortune in cutting discs!
SS1 diff mount help
Post by scimjim » Tue Apr 23, 2019 1:58 pm
yep - I've done a few!
The next one on the list is chassis number one - and it'll need doing without removing or cutting the tub or damaging the original show paint :shock:
MartinSS1
SS1 diff mount help
Post by MartinSS1 » Tue Apr 23, 2019 3:40 pm
Oh that's going to be a fun one! No pressure or anything :shock:
SS1 diff mount help
Post by scimjim » Tue Apr 23, 2019 3:49 pm
while you've got it stripped down, I'd make the front lower crossmember removable - then if you ever need to drop the sump, you can do it without having to take the engine out. I've also made a hole in the tub on my sprint car, so I can get a socket on the diff mount front nut (noting that the front bolt isn't central as I'm sure you know now :D )
MartinSS1
SS1 diff mount help
Post by MartinSS1 » Tue Apr 23, 2019 5:18 pm
Good tip!
