1600 cvh
Has thanked: 23 times
1600 cvh
Post by Alan SS1 » Thu Nov 01, 2018 12:37 pm
scimjim wrote:
Wed Oct 31, 2018 5:34 pm
Alan SS1 wrote:
Wed Oct 31, 2018 12:44 pm
scimjim wrote:
Tue Oct 30, 2018 10:29 pm
Sounds like it’s probably out of an XR2 originally - standard SS1 exhaust will bolt straight up.
would that not depend on the design of the 4-2-1 ??? ie how far down under the sump the 2-1 part was . . . . some had a twin pipe running down front of block and only became 'one' at sump level (in XR3 version)
You misunderstand - like Richard I have an XR 4-2-1 and it’s a massive job to make any of it fit - just use the original manifold and exhaust.
Jim , my original post was just making clear that the only thing that would fit is the gasket :shock: , ie as you say 'use the manifold from SS1' :D
unclebob1951
1600 cvh
Post by unclebob1951 » Fri Nov 09, 2018 2:03 pm
I've got it! My engine is tired, with low compression on no.1 cylinder, and I thought this might save me some cost and bother. On rolling road it was putting out 70 horses vs. original 95.
Dizzy is at the back. I will sell on the gearbox, sump and exhaust manifold, and the rocker cover as I already have a Sierra 1.8 one.
Not sure about carb setup. Any advice on preference for my standard carb vs. tldm xr2 28/32 that came with it? Spark plugs were quite sooty, so some work probably needed to tune it.
Bob Powell
SS1 1.6 1985
Former SE6a owner
unclebob1951
1600 cvh
Post by unclebob1951 » Sat Nov 17, 2018 3:09 pm
FYI, took the head off and it's a lean burn one. Bottom end looks good, but will now have to think about swapping hemi head and pistons from old engine, with new rings. Everything I read says lean burn head loses about 5 horses. How tough are big ends and mains on these engines? Am i likely to need to change those?
Bob Powell
SS1 1.6 1985
Former SE6a owner
