Re-placing & re-route fuel pipes
Been thanked: 225 times
Post by AJL Electronics » Sun Sep 30, 2018 9:17 am
My advice is to avoid copper due to work hardening effects. The only way to avoid them is by careful clipping to avoid any vibration at all. So the ideal choice is OEM nylon which you can still buy off the roll. Otherwise Kunifer will do the job. You will need to make a double flare at the ends to ensure a good seal, especially on the injected vehicles.
Rattling
Post by Rattling » Sun Sep 30, 2018 9:35 am
Thanks for the further information Andy do you have any of the OEM nylon and do you know how much I would need accounting for the extra length advised in the other posts .
Colin
1800 Ti
Ford
Post by Ford » Sun Sep 30, 2018 10:34 am
2m is just enough, costs a few pounds per metre.
1/4" OD return and 5/16" (or 8mm) OD feed
SS1 1316
Rattling
Post by Rattling » Sun Sep 30, 2018 4:09 pm
Many thanks for that Ford
Colin
1800 Ti
