Front damper length?
rhss1
Post by rhss1 » Sun Sep 16, 2018 4:03 pm
Some Avo adjustables have come up on a large auction site. They are listed as 13". I'm too far from the car to measure; will they be right for the front of an SS1?
If yes, a guide as to spring rates please, car is to be a nice driver, nothing more exciting.
[later after some more digging]
Apparently originals are 15".
Also http://www.ss1turbo.co.uk/hot_hatch_hunting.htm also suggests spring rates should be slightly less that what is spec'd for original geometry.
Been thanked: 842 times
Post by scimjim » Sun Sep 16, 2018 4:49 pm
You’ve already asked this question here.
I can’t see where it recommends softer springs in Craig’s article? Certainly wouldn’t be my recommendation. Standard are around 180 IIRC.
Has thanked: 248 times
Been thanked: 223 times
Post by CNHSS1 » Sun Sep 16, 2018 7:06 pm
Doesnt say softer springs ;-)
rhss1
Post by rhss1 » Sun Sep 16, 2018 8:42 pm
I thought this bit in the hot hatch article suggested slightly softer springs for coilovers, but maybe that's just my reading simple english to mean what it says:
"By using 1.9” adj. spring seat coilover front shocks with 8” 1.9” ID springs, you can bin the std. front springs and have a huge range of spring rates available to you. I’ve used this method on my racers and it works a treat. Ride height can be adjusted in seconds (yes really) and simplifies things too. If your going to buy new shocks anyway, why not try this method. The only thing to note though, is that to achieve the same suspension spring rate at the wheel (known as the wheel rate) as a setup with the springs in the original position, you must use a slightly lower poundage spring. As an example, I used 400lb/in springs on a sprinter in the original factory position between the wisbones, but to achieve the same rate when using the inboard coilover design, I needed 350lb/in springs."
rhss1
Post by rhss1 » Sun Sep 16, 2018 8:44 pm
Yes, I know - no answers there either.
Post by scimjim » Sun Sep 16, 2018 9:15 pm
This is talking about using coil overs instead of the separate spring/damper setup that it has as standard.
Post by scimjim » Sun Sep 16, 2018 9:23 pm
We don’t start a new thread if there’s no answer inside 4 hours :-)
Front
Open length bush eye to eye is 13.5" standard
Bush ID is 3/8"
Bush width is 1" (25.4mm)
Rear
Bush ID is 1/2"
Bush width is 1" 5/16" (33.33mm)
rhss1
Post by rhss1 » Sun Sep 16, 2018 10:21 pm
Perhaps I needed to make my original post a little easier to understand (this part):
"...spring rates should be slightly less that what is spec'd for original geometry."
[hot hatch says above - twice - that 350 coilover is the same wheel rate as 400 "...in the original factory position between the wisbones [sic]"
Anyhow, thanks very much for the numbers. I will measure and double-check (hot hatch says 15", and after receiving two different answers to the question of hub nut size it's possibly another case of what's on my car not being what others think should be there).
Post by scimjim » Sun Sep 16, 2018 10:47 pm
Apologies, you didn’t say anywhere that you are you planning on changing to inboard springs? If so, are you putting lower poundage springs in the original position too, or will you be modifying the lower balljoint mounting?
rhss1
Post by rhss1 » Sun Sep 16, 2018 11:26 pm
Yes, converting to inboard springs was what I was considering. I didn't know you could have coilovers with the springs in the original position on the SS1 - how does that work?
And if so what modification(s) to the lower balljoint is/are needed?
Post by scimjim » Sun Sep 16, 2018 11:57 pm
The lower baljoint is simply pressed into the wishbone and retained by the reaction of the spring against the wishbone. If you remove the spring, you risk the balljoint popping out, so weld it in or (better still) fit a removable strap.
Where does it say the dampers are 15” - Phil can amend it.
Post by CNHSS1 » Mon Sep 17, 2018 7:50 am
Is the car going to be used on the road a lot? If so, as per my article (written 2004 btw!) The upper arms need a fair bit of strengthening, over and above the various mods reliant did during production (no way of knowing from your posts how many, if any, of the revisions you have on your top arms).
Personally I tack weld in 3 or 4 places the ballpoint, allowing to cool after each weld so as not to damage the balljoint internally and also add a catch strap between the two sides of the wishbones channel to ensure even if the ball joint came loose, it couldn't work it's way out of the wishbone hole.
Spring rates are dependant on engine weight and usage. Is the car track only? For a pure racer you can run uber stiff, but the front crossmember beam takes more load so ensure the captive nuts are in good order, or it'll work loose
As Jim has mentioned, you can also fit assister springs as coilovers. On my Sabre, I ran 400lb between the wheels with 115lb (iirc) on the damper. Advantage is that you can alter preload for corner weighting and alter ride height. Also reduce load on top arms by a large margin over coil over only. Pics in my project threads ' Batmobile ' and also ' Light Sabre '
Post by CNHSS1 » Mon Sep 17, 2018 7:55 am
As fitted to light sabre 13.5" eye to eye
Post by CNHSS1 » Mon Sep 17, 2018 7:58 am
Also I'm 99% sure the original Monroe's were longer, hence my 15" (I would have measured them back in the day) but as the original monroes were so dreadful, it's rather academic
When buying aftermarket shocks, check they can be used inverted As not all can due to the gas section design. It's important at the front as they run downhill, but essential at the rear as they are fitted unpsodw down to normal theory
HTH
Craig
Been thanked: 534 times
Post by philhoward » Mon Sep 17, 2018 8:14 am
I think Nick or Raz had one pop out first time out as it wasn't held in properly?
