Rusty fuel tank
HarrySS1
Rusty fuel tank
Post by HarrySS1 » Sat Aug 25, 2018 9:39 am
I poked a second hole in the tank so decided I would get be ss tank, will be with me on Wednesday.
Il post an update once fitted and tested after the weekend, fingers crossed il have a working car!!
Thanks for all the tips.
HarrySS1
Rusty fuel tank
Post by HarrySS1 » Fri Aug 31, 2018 8:22 am
The new SS fuel tank went in with a little wrestle, no major drama, it leaks from the fuel sender which is not a huge surprise by the looks of it, (not sure copper piping was ever a standard for fuel). Il be acquiring a new sender from QRG.
But also have a leak from the rubber fuel filler hose at its bottom end, hose clamp is nice and tight, any recommendations? Was a real bugger to get on!
The breather hose above that also fowled on my boot hinge, hence the cable ties, i seem to have it under control now. (the filler neck seemed to have raised up a little)
My other boot hinge seems to be stuck since i started this operation, any ideas on that?
Lots of questions, thanks in advance.
I hope the pictures and info will help someone doing a similar process themselves.
Been thanked: 561 times
Rusty fuel tank
Post by philhoward » Fri Aug 31, 2018 8:32 am
The sender connection is "previously repaired"..they do get a bit fragile!
Your hose clips look a little past their best from the picture - could be corrosion stopping you being able to nip it up fully?
David Tew
Rusty fuel tank
Post by David Tew » Fri Aug 31, 2018 9:41 am
There could also be damage to the internal lip of the hose. I've seen rust embedded in them before and it's very difficult to remove without causing more damage.
Probably worth fitting a new hose and stainless Mikalor clips
RSSOC member since 1978. 😲
big_billc
Rusty fuel tank
Post by big_billc » Fri Aug 31, 2018 10:14 am
I just typed and looked up the website, I was about to send when the last post came in. Decided to sent it anyway just for anybody who had the same problem.
The best thing is a S/S tank but is not cheap if money is an issue. If you want to clean & seal the inside and protect the outside look at below. They do a "Fuel Tank Renewal Kit" the small size for a SS1. Even if you get a second hand one, it is going to be very old and probably gundged up, so worth preserving it. I did it on my SS1 and was very happy with the result. I also had minor leaks which were completely sorted. Looking at your hole I am not sure how big it is, I suggest masking the outside with tape until it sets, or even GRP/isopon
http://www.rust.co.uk/fuel-ethanol-proo ... rs/c28114/
Old English White SE6A 2.9 EFI, Subaru White Sabre 1800Ti, Dark Grey Saab 9-3 My Scimitar spares collection car.
Problems : - Find a problem, Sort a problem, now there is no problem.
Has thanked: 27 times
Been thanked: 36 times
Rusty fuel tank
Post by Alan SS1 » Fri Aug 31, 2018 1:43 pm
ref boot hinge, remove and heat on gas stove, soak in favourite rust easing material, refit
BUT only remove ONE of the bolts that go into the boot lid at a time, ie remove hinge from the frame to allow the hinge to rotate on one bolt whilst remove it from hinge, put back temporarily, other wise the 'captive plate within boot lid might slide out of reach (been there)
dypcdiver
Rusty fuel tank
Post by dypcdiver » Sat Sep 01, 2018 12:05 pm
You have fallen into the same trap as I did. Only when i looked at the before and after photos did I realise that the tank was originally offset towards the right hand side. This could explain your leak on the filler hose and the fouling on the hinge.
Some mistakes are too much fun to only make once.
There are times when I think the gene pool could do with some chlorine.
Yellow peril, Sabre Turbo LHD
Previous:- 4 x Coupes. Se5a. Se6. SE6b. 1600 SS1. 1800 Ti. Presently:- Sabre Mk2 Turbo.
