CV Joints and Clips for Viscous LSD Conversion
Has thanked: 178 times
Been thanked: 188 times
Re: CV Joints and Clips for Viscous LSD Conversion
Post by CNHSS1 » Mon Jul 17, 2017 9:45 pm
Littlescim wrote:Craig said it was because the springs were missing so I bowed to his superior knowledge
Nowt superior about me mate I just break more than most :lol:
shropshire born and bred, strong in the arm and weak in the 'ead :lol:
frase29
Post by frase29 » Tue Jul 25, 2017 11:48 pm
Thanks for all the advice guys! I've got all the bits now, and am cracking on with the conversion - will be using the springs for sure :lol:
Struggled with the final removal of the trailing arm today - all apart except one of the two bolts where it pivots - can't get anything onto the nut that's tucked in behind the inner arch, argh! Will be heading to the lovely Halfords for a 24mm ring spanner tomorrow....
'87 SS1 1800ti: LSD, Megasquirt, EBC, Launch Control (oh and a decent stereo ;) )
td99
Has thanked: 15 times
Post by td99 » Wed Jul 26, 2017 8:40 am
frase29 wrote:Thanks for all the advice guys! I've got all the bits now, and am cracking on with the conversion - will be using the springs for sure :lol:
You could try cutting a socket to a "short" version, that works a treat on a ratchet.
Trevor - 1800Ti daily driver
1800Ti DET project, RAV4
Been thanked: 435 times
Post by Roger Pennington » Wed Jul 26, 2017 6:16 pm
I used one of these - Laser extra-long ring spanner - the extra length gave plenty of leverage and the flat shape meant it fitted in the tight spot.
td99
Post by td99 » Wed Jul 26, 2017 7:34 pm
Short socket...
drag'n drop didn't work... will try more...
Don't seem to be able to add a picture...
Has thanked: 112 times
Been thanked: 755 times
Post by scimjim » Wed Jul 26, 2017 8:07 pm
New thread started here
frase29
Post by frase29 » Wed Jul 26, 2017 10:12 pm
Managed to get it off with a standard 24mm spanner - though I can see a shortened socket would be ideal...
Struggled with a few bits but the old open diff is finally off - fingers crossed with no big issues it'll all be back together tomorrow...
Having got it all apart to look at now, I'm slightly confused as to where the spring will go on the inner joint? If the CV's are bolted to the flanges on the diff, and held in place on the shaft with circlips then where could the spring go, and how would it move the shaft? I'm pretty sure i'm missing something here, so please put me right!
