Small sports Rear hub bearings
Has thanked: 129 times
Been thanked: 938 times
Post by scimjim » Mon Feb 17, 2014 9:04 am
Just found a site that lists lots of bearings - indirect cross interchange seems to mean they don't include the circlip and/or new nut (I checked a few on this site) - anyway, it may help someone, so SS1 rear bearings / mk2 mazda 626 11/82-09/87 (QH QB619) show up as:
Factory Number Cross Interchange Type Relevance
SKF VKBA899 Direct Cross Interchange 23
OPTIMAL 941734 Direct Cross Interchange 21
SPIDAN 26628 Direct Cross Interchange 19
FAG 713615140 Direct Cross Interchange 18
RUVILLE 7007 Direct Cross Interchange 18
SNR R17007 Direct Cross Interchange 17
A.B.S. 200402 Direct Cross Interchange 14
KACO 30591 Direct Cross Interchange 12
FIRST LINE FBK106 Direct Cross Interchange 10
LUCAS ENGINE DRIVE LKBA82030 Direct Cross Interchange 9
sbs 1401753205 Direct Cross Interchange 9
NK 753205 Direct Cross Interchange 9
TRISCAN 853050107 Direct Cross Interchange 8
CORTECO 19019580 Direct Cross Interchange 8
DELPHI BK466 Direct Cross Interchange 8
DELPHI WBK466 Direct Cross Interchange 8
AUTEX 802519 Direct Cross Interchange 7
IPD 301514 Direct Cross Interchange 6
BRT Bearings BRT1298 Direct Cross Interchange 6
Automotive Bearings ABK1298 Direct Cross Interchange 6
BREDA LORETT CR7051 Direct Cross Interchange 6
MAZDA H00126151 Direct Cross Interchange 6
DELPHI BK663 Direct Cross Interchange 5
MAZDA H00126151B Direct Cross Interchange 5
UNIPART GHK1262 Direct Cross Interchange 5
MOTORCRAFT EUB1143 Direct Cross Interchange 4
AUGROS 51878080 Direct Cross Interchange 4
SPIDAN 0026628 Direct Cross Interchange 4
TIMKEN EK78689 Direct Cross Interchange 4
TIMKEN 78689 Direct Cross Interchange 3
DELTA AWB380 Direct Cross Interchange 3
NPS M470A02 Direct Cross Interchange 3
TIMKEN K81934 Direct Cross Interchange 2
AUGROS 51878098 Direct Cross Interchange 2
POWERPART 01824 Direct Cross Interchange 1
POWERPART 1301 Direct Cross Interchange 1
POWERPART 1514 Direct Cross Interchange 1
POWERPART 7007 Direct Cross Interchange 1
POWERPART ABK1298 Direct Cross Interchange 1
POWERPART ADM58209 Direct Cross Interchange 1
POWERPART BBK440 Direct Cross Interchange 1
POWERPART BRT1298 Direct Cross Interchange 1
POWERPART CX052 Direct Cross Interchange 1
POWERPART FBK106 Direct Cross Interchange 1
POWERPART KIT220 Direct Cross Interchange 1
POWERPART PTWB767 Direct Cross Interchange 1
POWERPART SBK619 Direct Cross Interchange 1
POWERPART TBK220 Direct Cross Interchange 1
POWERPART VK313 Direct Cross Interchange 1
POWERPART WBS899 Direct Cross Interchange 1
COPARTS 7104 Direct Cross Interchange 1
SAMKO 2509 Direct Cross Interchange 1
HK 1514 Indirect Cross Interchange 14
FLENNOR FR930623 Indirect Cross Interchange 10
KAWE FR930623 Indirect Cross Interchange 10
BENDIX 050881B Indirect Cross Interchange 8
BLUE PRINT ADM58209 Indirect Cross Interchange 6
SK SK18990 Indirect Cross Interchange 6
HERTH+BUSS JAKOPARTS J4703002 Indirect Cross Interchange 6
A.B.S. 200501 Indirect Cross Interchange 5
JAPANPARTS KK13002 Indirect Cross Interchange 5
RPK RPK18990 Indirect Cross Interchange 5
JAPKO 413002 Indirect Cross Interchange 5
ASHIKA 4413002 Indirect Cross Interchange 5
MASTER-SPORT 899SETMS Indirect Cross Interchange 5
KAGER 830285 Indirect Cross Interchange 4
QUINTON HAZELL BK10619 Indirect Cross Interchange 4
NIPPARTS J4703002 Indirect Cross Interchange 4
UNIPART GHK1262 Indirect Cross Interchange 4
MOTAQUIP VBK379 Indirect Cross Interchange 3
PM 810929 Indirect Cross Interchange 3
QUINTON HAZELL QWB257 Indirect Cross Interchange 3
QUINTON HAZELL QWB510 Indirect Cross Interchange 3
QUINTON HAZELL QWB762 Indirect Cross Interchange 3
DT Components 513014 Indirect Cross Interchange 3
Precision Seals & Bearings 513014 Indirect Cross Interchange 3
CENTRO 0986005083 Indirect Cross Interchange 3
TIMKEN SET39 Indirect Cross Interchange 2
NSK-RHP 39BWD03CA69 Indirect Cross Interchange 2
NTN 4TCR10868 Indirect Cross Interchange 2
WESSELS & MüLLER 9273046 Indirect Cross Interchange 2
MOTORCRAFT ERB108 Indirect Cross Interchange 2
Precision Seals & Bearings B38 Indirect Cross Interchange 2
DT Components B38 Indirect Cross Interchange 2
KAGER 830245 Indirect Cross Interchange 2
DOYEN 941734 Indirect Cross Interchange 2
UNIPART 1262 Indirect Cross Interchange 2
STAHLGRUBER 3655304 Indirect Cross Interchange 2
FAG 528810A Indirect Cross Interchange 2
FAG 540733A Indirect Cross Interchange 2
FAG 540733C Indirect Cross Interchange 2
FLENNOR FR931627 Indirect Cross Interchange 2
BECK/ARNLEY 0513852 Indirect Cross Interchange 2
BECK/ARNLEY 0513858 Indirect Cross Interchange 2
ACL ADM58209 Indirect Cross Interchange 2
PERFECT CIRCLE B38 Indirect Cross Interchange 2
CORTECO 19019597 Indirect Cross Interchange 2
NATIONAL 513014 Indirect Cross Interchange 2
SKF BA2B309692 Indirect Cross Interchange 2
SKF BAHB311315BD Indirect Cross Interchange 2
SKF BAHB311315DD Indirect Cross Interchange 2
SKF 309396 Indirect Cross Interchange 2
SKF FWB38 Indirect Cross Interchange 2
NTN DE0819LLCS385C Indirect Cross Interchange 2
SKF VKBA575 Indirect Cross Interchange 2
PEX 160185 Indirect Cross Interchange 2
MAZDA H00126151A Indirect Cross Interchange 2
BCA B38 Indirect Cross Interchange 2
GREEN RW811 Indirect Cross Interchange 2
ITM 3802001 Indirect Cross Interchange 2
ITM 3802004 Indirect Cross Interchange 2
ITM 3803312 Indirect Cross Interchange 2
LAZORLITE L812617 Indirect Cross Interchange 2
LAZORLITE U813168 Indirect Cross Interchange 2
SEALED POWER BFV38 Indirect Cross Interchange 2
SEALED POWER FFV38 Indirect Cross Interchange 2
VERA 6401003 Indirect Cross Interchange 2
VERA 6401623 Indirect Cross Interchange 2
VERA 6402042 Indirect Cross Interchange 2
FORD H00126151 Indirect Cross Interchange 2
LuK 7136151400 Indirect Cross Interchange 2
CR B38 Indirect Cross Interchange 2
CR FW108 Indirect Cross Interchange 2
CR WBK575 Indirect Cross Interchange 2
L&S Bearing B38 Indirect Cross Interchange 2
L&S Bearing FV38 Indirect Cross Interchange 2
L&S Bearing IO38 Indirect Cross Interchange 2
ABC B38 Indirect Cross Interchange 2
ABC FV38 Indirect Cross Interchange 2
ABC IO38 Indirect Cross Interchange 2
VOLKSWAGEN 191498625D Indirect Cross Interchange 2
VOLKSWAGEN 321498625A Indirect Cross Interchange 2
VOLKSWAGEN 321498625B Indirect Cross Interchange 2
VOLKSWAGEN 321498625C Indirect Cross Interchange 2
VOLKSWAGEN 321498625D Indirect Cross Interchange 2
VOLKSWAGEN 331598625 Indirect Cross Interchange 2
VOLKSWAGEN 811406625B Indirect Cross Interchange 2
VOLKSWAGEN 811407625A Indirect Cross Interchange 2
VOLKSWAGEN 811407625B Indirect Cross Interchange 2
VOLKSWAGEN 811407625D Indirect Cross Interchange 2
VOLKSWAGEN 811407625E Indirect Cross Interchange 2
VOLKSWAGEN 811407625F Indirect Cross Interchange 2
VOLKSWAGEN 823407625B Indirect Cross Interchange 2
McQuay-Norris BT38B Indirect Cross Interchange 2
IAPCO L0101029 Indirect Cross Interchange 2
IAPCO L0180003 Indirect Cross Interchange 2
WORLD PARTS W72428 Indirect Cross Interchange 2
BREDA LORETT CR7057 Indirect Cross Interchange 1
BREDA LORETT CR7561 Indirect Cross Interchange 1
SKF VKBA904 Indirect Cross Interchange 1
MAZDA B00133043 Indirect Cross Interchange 1
MAZDA H00126139 Indirect Cross Interchange 1
PEX 160186 Indirect Cross Interchange 1
PEX 160292 Indirect Cross Interchange 1
DELPHI BK467 Indirect Cross Interchange 1
AUGROS 51878221 Indirect Cross Interchange 1
NTN 4TCR10868LLCS103 Indirect Cross Interchange 1
NTN 4TCR10868LLCS150L26 Indirect Cross Interchange 1
FAG 713615190 Indirect Cross Interchange 1
FAG 713615210 Indirect Cross Interchange 1
CORTECO 19019581 Indirect Cross Interchange 1
TIMKEN K78689 Indirect Cross Interchange 1
SKF VKBA1354 Indirect Cross Interchange 1
SKF B38 Indirect Cross Interchange 1
SKF FW113 Indirect Cross Interchange 1
A.B.S. 200661 Indirect Cross Interchange 1
BENDIX 050886B Indirect Cross Interchange 1
RUVILLE 7008 Indirect Cross Interchange 1
RUVILLE 7020 Indirect Cross Interchange 1
SPIDAN 26745 Indirect Cross Interchange 1
LEMFORDER 1917001 Indirect Cross Interchange 1
SBS 753205 Indirect Cross Interchange 1
TRISCAN 1202713615140 Indirect Cross Interchange 1
TRISCAN 1514 Indirect Cross Interchange 1
TRISCAN 30KH1268 Indirect Cross Interchange 1
TRISCAN 7210655 Indirect Cross Interchange 1
TRISCAN FBK106 Indirect Cross Interchange 1
TRISCAN FBK626 Indirect Cross Interchange 1
TRISCAN R17007 Indirect Cross Interchange 1
TRISCAN WBK466 Indirect Cross Interchange 1
BOSAL 136021 Indirect Cross Interchange 1
BOSAL 136872 Indirect Cross Interchange 1
LUCAS ENGINE DRIVE LKBA82043 Indirect Cross Interchange 1
QUINTON HAZELL QWB940 Indirect Cross Interchange 1
QUINTON HAZELL QWB602 Indirect Cross Interchange 1
QUINTON HAZELL QBA666 Indirect Cross Interchange 1
MOTORCRAFT EUB1048 Indirect Cross Interchange 1
UNIPART GHK1339 Indirect Cross Interchange 1
MASSEY FERGUSON 51878080 Indirect Cross Interchange 1
MASSEY FERGUSON 51878098 Indirect Cross Interchange 1
WERTHENBACH 7104 Indirect Cross Interchange 1
SCHAEFFLER GRUPPE 713615140 Indirect Cross Interchange 1
SOLID AUTO (UK) M237004 Indirect Cross Interchange 1
KAGER 830455 Indirect Cross Interchange 1
AP WBK466 Indirect Cross Interchange 1
BLUE PRINT ADM58214 Indirect Cross Interchange 1
BLUE PRINT ADT38315 Indirect Cross Interchange 1
AUTEX 802524 Indirect Cross Interchange 1
AUTEX 802526 Indirect Cross Interchange 1
TOPRAN 401363 Indirect Cross Interchange 1
SKF VKBA899 Indirect Cross Interchange 1
FLENNOR FR931455 Indirect Cross Interchange 1
FLENNOR FR931508 Indirect Cross Interchange 1
SPIDAN 0026629 Indirect Cross Interchange 1
SPIDAN 0026745 Indirect Cross Interchange 1
SPIDAN 26752 Indirect Cross Interchange 1
IPD 301519 Indirect Cross Interchange 1
IPD 301521 Indirect Cross Interchange 1
KAWE FR931508 Indirect Cross Interchange 1
KAWE FR931627 Indirect Cross Interchange 1
sbs 1401753203 Indirect Cross Interchange 1
NK 763203 Indirect Cross Interchange 1
OPTIMAL 942566 Indirect Cross Interchange 1
OPTIMAL 942619 Indirect Cross Interchange 1
OPTIMAL 942738 Indirect Cross Interchange 1
FAG 1514 Indirect Cross Interchange 1
NK 753203 Indirect Cross Interchange 1
Automotive Bearings ABK344 Indirect Cross Interchange 1
BRT Bearings BRT656 Indirect Cross Interchange 1
SNR R17008 Indirect Cross Interchange 1
SNR R17020 Indirect Cross Interchange 1
KM International RK1514 Indirect Cross Interchange 1
CALIBER RC1514 Indirect Cross Interchange 1
AUTOTEAM RA1514 Indirect Cross Interchange 1
NPS T471A30 Indirect Cross Interchange 1
ASHUKI 14102003 Indirect Cross Interchange 1
TRISCAN 853050208 Indirect Cross Interchange 1
Usual disclaimers about what you find on the net etc!
Re: Rear hub bearings
Post by scimjim » Wed Jun 14, 2017 8:05 pm
Some more numbers
QWB619
The Original Dimensions: Inner Dia:38,75mm Out Dia:68,00mm Width:37,00mm
To fit:
Mazda 626 1982-1987 Wheel Bearing Kit Front
Mazda 626 1983-1987 Wheel Bearing Kit Front
Mazda 626 1986-1987 Wheel Bearing Kit Front
Analogues/Similar parts:
Autokit: 1.824
MEDINABI: 1301
Helmut Klotz: 15/14
Kaco: 3059.1
Ruville K.G.: 7007
COPARTS: 7104
OPTIMAL: 899
Bearings: ABK1298
Auto Delta: AWB380
Balco: BBK440
MOPROD: BK428
DELPHI: BK466
BRT: BRT1298
CX Complex: CX052
TIMKEN: EK78689
MOTORCRAFT: EUB1143
FIRSTLINE: FBK106
UNIPART: GHK1262
TIMKEN: K81934
Technostart: KIT220
POWERTRAIN: PTWB767
SNR: R170.07
Sandalloy: SBK619
TRUPART: TBK220
Veco: VK313
SKF: VKBA899
DELPHI: WBK466
Sandalloy: WBS899
bettaparts: LBK8305
Bettaparts: LBK8305
Been thanked: 347 times
Post by peter freeman » Thu Jun 15, 2017 8:02 am
Difficult to find a replacement then ? - I wish the fronts were as easy to find - I tried to find two bearings which I could fit back to back to replace the single unit but had no luck - its the diameter which causes the replacement problem.
Post by scimjim » Thu Jun 15, 2017 2:34 pm
Nope - rears are currently widely available and cheap.
