1800TI Distributor
Has thanked: 49 times
Been thanked: 589 times
1800TI Distributor
Post by philhoward » Tue Jun 04, 2013 8:05 am
Very handy PDF from Jim Russell on optical eye replacement..
SCIMITAR SS1 TURBO 1800TI CAM ANGLE SENSOR INSTALLATION.pdf
(1.37 MiB) Downloaded 267 times
stewb
Re: 1800TI Distributor
Post by stewb » Sat Dec 06, 2014 8:45 pm
Wonder if you can use the eye asembly from the CAS used on the dizzyless engines? They use the same dual eye setup & triggering pattern.
Ex Owner of MK2 Scimitar Sabre CA18DET
'69 Tuscan V8 project which wasn't meant to be a project....
Capri 2.8 Injection Special
'09 GTM Libra - Honda K20 VTEC
"if you do something to be impressive rather than good, you're doomed" - Spen King
