Replacing the rear hatch Rubber
Been thanked: 473 times
Re: Replacing the rear hatch Rubber
Post by Roger Pennington » Thu Aug 11, 2011 10:48 pm
I'm in much the same position as Taggers in the other thread - I've got a disintegrating hatch on the Yellow Peril, and I've bought one of Bill's fixing kits and Viv's rubbers, but I haven't been able to pluck up the courage to rip the thing apart :oops:
I thought the idea was that the joiner pieces and screws were completely hidden inside the frame (as original?) but I may be wrong? :?
Been thanked: 540 times
Post by philhoward » Fri Aug 12, 2011 5:23 am
I would assume strip on the inside and screws from the outside? I've seen some pics (involving sash clamps...) but can't find them!
Been thanked: 854 times
Post by scimjim » Sat Aug 13, 2011 11:37 am
speak to Viv he's done several.
Coco La Blanc
Post by Coco La Blanc » Tue Aug 30, 2011 11:27 pm
Dodger,
Just got back from Curborough/Cambridge/West Sussex Caravan extravaganza so response is somewhat late !!!
If you're that worried about completing the rebuild of your Hatch you can always bring it down, just 8 or 9 miles past Goodwood, for a 'visit' (Tea's included !) and I'll do it for a small contribution to the 'Scimitar(s) - GTE/SS1/Sabre' upkeep fund !!! ;~} As previously stated it will take somewhere between 90-180 minutes dependent on ease of reassembly and cleanup. I suggest that you check condition of 'T' seal as this may require renewal as it's not always possible to remove without damage to this seal.
Jim & All,
As Chairman Phil states - Strip (preferably SS or Brass) on the inside and 2 x 2BA (similarly SS or Brass) bolts with countersunk heads recommended to be used (all required parts included in Bill Brighton's repair kits).
Regards,
Viv
Post by Roger Pennington » Wed Aug 31, 2011 11:51 am
Hi Viv, thanks for the offer, it's likely to be at least a month before I'm in a position to do anything about it as I've got a lot on over the next 3 -4 weeks (including the Rvival :D ) so I'll need to get in touch then. I agree about the T seal, I'd better get some ordered (unless you have stock). I've got one of Bill's kits and a length of your glass seal already.
cheers,
scmarf
Post by scmarf » Wed Nov 02, 2011 1:48 pm
I did the glass-to-frame seal last year. Not an easy job. Didn't enjoy levering and hammering around the glass but it worked. I will post some pictures when I get a moment. Main motivation was parting of the two halves through corroded plates. From memory, tips were:
1. Countersink the threaded holes to get a snug fit for the screws (avoids a bump in the outer T seal)
2. Check if screws protrude beyond the bracket (onto the edge of the glass) and dress if they do (mine did).
3. I used plenty of silicone lubricant - washing up liquid apparently contains salt!
4. Trim (for thinner cross section)the rubber around the fixings as the channel is tighter there, and the rubber I used was a tight fit. Would be interested if Viv uses the same supplier - and what Reliant used.
5. I was convinced the frame would never go back without damage when I tried to put the bottom half back on. Wish I had read this article before! Thanks DD. :)
6. You will end up trimming the length as you pull the frames together as it stretches during assembly.
7. The professionals just use Sikaflex and matchsticks for positioning.
Must go - luchtime over.
Honda Jazz
scmarf
Post by scmarf » Wed Nov 02, 2011 11:10 pm
Well, it kind of got out of hand. I just e-mailed an account to Terry Trunnion complete with pictures for Slice.
Honda Jazz
wes wilson
Post by wes wilson » Wed Feb 04, 2015 9:39 pm
DanDrums wrote:Joe: I used a black silicone sealer in a cartridge gun. It's Everbuild - Everflex LMA 200. Black.
I also put some on the front windscreen rubber where it's cracked up a bit on the corners. If it starts to come away, I'll post it up on this thread
Dan
i used this ten years ago to repair the window seals on my ss1 and they are still intact and wiping the door windows as good as the originals
Has thanked: 118 times
Been thanked: 21 times
Post by willholderogri » Mon May 08, 2017 12:12 pm
very useful thanks
