XJS electric mirrors wiring
Been thanked: 218 times
Post by AJL Electronics » Sat Jul 29, 2017 6:49 pm
The original isn't a Ford switch, no idea where it came from. Middlebridge started using the Ford switch and it is a much nicer job, getting rid of the rocker switch.
Been thanked: 877 times
Post by scimjim » Wed Aug 02, 2017 5:04 pm
Wiring pictures from Dennis - I'll make this a sticky in how-to?
XJS mirror 1_0001.jpg (99.3 KiB) Viewed 3164 times
XJS mirror 1.jpg (83.73 KiB) Viewed 3164 times
XJS mirrors 2.jpg (135.96 KiB) Viewed 3164 times
Terry H
Been thanked: 43 times
Post by Terry H » Wed Aug 02, 2017 5:17 pm
May be a good idea to add the Ford mirror switch to the same sticky as it's a better switch. Just an idea.
Regards Terry H
1185
Post by scimjim » Wed Aug 02, 2017 5:54 pm
POWER_MIRRORS.pdf
(28.48 KiB) Downloaded 99 times
ard126k
Post by ard126k » Thu Aug 03, 2017 8:11 pm
Thanks seem inadequate Jim and Dennis....
Alex.
1971 SE5 1977 SE6 1982 GTC
ard126k
Post by ard126k » Mon Aug 07, 2017 9:40 am
I now have a Ford switch, the wire colours are somewhat different to Jim's PDF but some amateurish fumbling with a meter has revealed which wires connect to each other at each switch position so I think I'm making progress. Mirrors should arrive this week and then the real fun can begin!
Alex.
Terry H
Post by Terry H » Mon Aug 07, 2017 10:07 am
Just found this Alex, it is the Ford switch wiring instructions. I cant remember who the author is but it could be AJL.
Wiring...
Power to pin 6
Earth to pin 4
the common of all motors goes to pin 3
Left vertical goes to pin 1
Left horizontal goes to pin 7
Right vertical goes to pin 2
Right horizontal goes to pin 5
The mirror motors have two pairs, green and white and blue and yellow. A quick test with a PP3 will show which way they are connected. Just connect the negatives together to make the three wire link.
Mirror colours
Left hand (nearside mirror) working as follows:
Join the blue and green and connect to pin 3 (common)
Connect yellow from mirror to pin 1
Connect white from mirror to pin 7
Right hand (offside mirror)
Connect yellow from mirror to pin 2
Connect white from mirror to pin 5
Hope this Helps.
Regards Terry H
1185
ard126k
Post by ard126k » Mon Aug 07, 2017 2:48 pm
Thanks to you Terry and the original author, may well have been AJL.
The details agree with what I'd worked out, save that I thought pin 6 must be earth due to it having two black wires.... can't imagine that would cause any bother apart from the mirrors going the 'wrong' way.
Alex.
ard126k
Post by ard126k » Sat Aug 12, 2017 6:08 pm
Mirrors arrived, all seems OK. I was a bit doubtful that a PP3 battery would run the motors, should have known better.
I'm thinking of painting them body-colour, if I can get the plastic surround off. Does anyone know how to dismantle these mirrors?
ard126k
Post by ard126k » Tue Sep 05, 2017 11:37 pm
It is done! A bit of a saga due to having four different sets of colours in the wiring (on the mirrors, the original Scimitar loom, the Ford switch and a length of multicore I had to buy because I'm moving the switch to the driver's door) but several pages of notes and a bit of trial and error got there in the end. One slight amendment - I moved the connector from position 6 on the switch to position 3 to give me a common wire for each mirror. Seemed the neatest way to do it.
I also found out how to take them apart - turn the mirror fully inwards, then prise off gently with something wide - I used a steel rule. The mirror backing sits on 3 ball-and-socket joints which can each be undone in this way. Thanks to Corky who let me into the secret!
ard126k
Post by ard126k » Fri Apr 27, 2018 5:59 pm
I thought I'd just finish this thread off with pics of the finished job, I found that there's room between the door body and the door card to hold the wiring
not my finest GRP work but it's hidden... and the switch where the joystick for the manual mirror would go -hole also enlarged a bit
RonH
Post by RonH » Fri Apr 27, 2018 8:35 pm
Good timing.
Look what turned up in the post today. Brand new old stock!! 404’s future spares maybe.
Has thanked: 154 times
Been thanked: 158 times
Post by Corky » Fri Apr 27, 2018 8:55 pm
I did the same with HOM450W, but I couldn’t make the Ford switch work, so put an XJS switch on the door instead. Following suit on no.404.
Electrics have never been my strong point :lol:
RonH
Post by RonH » Fri Apr 27, 2018 9:23 pm
Those xjs switches appear to be a little rare at the moment (except from USA with expensive shipping) I’ve been wanting one for a while now. I should have bought one a couple of years ago. But I’ll keep seeking and eventually I’ll find.
Ron
