axle upgrade
Threads will be locked once posted, so any further questions in the specific forum, please.
Locked
truckdoctor
axle upgrade
Post by truckdoctor » Tue Aug 09, 2011 3:30 am
Scimitar axle
Hello everyone, could some technicaly minded people help with a request I have regarding Jaguar Differentials ?
I have been told that a differential from an xjs v12 differential (2.8:1 ratio ) would fit into a scimitar axle casing using the existing half shafts etc . Is this so? and what are the widths of these axles from hub to hub and whichIs specific axle should be used?
The reason for asking is a project I have needs a replacement axle with a ratio as close as posible to 2.8:1
Thanks in advance
Has thanked: 112 times
Been thanked: 770 times
Re: axle upgrade
Post by scimjim » Sat Aug 13, 2011 3:19 pm
busy catching up on several weeks of posts - sure I've read this already though (and it's not a "how to guide")?
Been thanked: 437 times
Re: axle upgrade
Post by Roger Pennington » Sat Aug 13, 2011 3:29 pm
Yes, you're right Jim it's Here. This duplicate now locked
Locked
Return to “How To Guides”
