GTC 374
monkey135
GTC 374
Post by monkey135 » Tue Sep 10, 2019 7:58 pm
A brief intro now I have it registered (was on Irish plates). Bought this in July, generally very pleased with it. Not sure if it is on the register?
Got a carb question...... it's on a Weber 38dgas but doesn't run 'right'. 'Hunting' at idle and just doesn't pull right, bogs down. Already established the fuel jets are the wrong size but what does this do (circled in picture)? It's an open hole with nothing in it, should it have something connected?
Regards,
Ian
Ian
'83 GTC
guybetts
GTC 374
Post by guybetts » Tue Sep 10, 2019 9:39 pm
Hi Ian,
Welcome to GTC ownership.
I took a few pics of the GTC's at Curborough in order to record cars there and check against the register. I spotted yours which wasn't on the register with the registration number (obviously now), but I didn't see you :(
JBW998Y
At least now I know which GTC it is :D and it is on the register.
Please can you pm me or drop me an email gtc.registrar@rssoc.co.uk with your details, so I can update the register.
As to your Weber Carb issue, I'll leave that to someone with better technical knowledge... someone will probably be along soon enough :)
Thanks,
Guy
GTC Registrar
Has thanked: 186 times
Been thanked: 1266 times
GTC 374
Post by scimjim » Tue Sep 10, 2019 10:20 pm
Is it an open hole, or an undrilled boss?
ard126k
Been thanked: 44 times
GTC 374
Post by ard126k » Wed Sep 11, 2019 5:37 pm
I think they all have that, don't they? Must be for some other application.
Where did you find the jet sizes for a 2.8? I've only ever seen them for 3.0 Essexes?
Alex.
1971 SE5 1977 SE6 1982 GTC
Geraint SabreGTCse5
Been thanked: 64 times
GTC 374
Post by Geraint SabreGTCse5 » Wed Sep 11, 2019 5:53 pm
Alex.
the receipt for rejetting a dgas fitted to one of my c's gives the following spec Main jet 142 Air jet 185 idle jet 5.... it was done some time ago but new dgas carbs can be bought for the 2.8
Geraint
monkey135
GTC 374
Post by monkey135 » Wed Sep 11, 2019 7:30 pm
Main jets are currently 135 so I bought some 145's as I read somewhere that was correct. The hole I referred to is open (i.e. not just an undrilled boss) but a couple of people have now confirmed it's the same so I guess that's not the issue.
There are a few pipes blanked off with bolts in the end of rubber pipes (mainly what I assume are vacuum pipes into the manifold/base of the carb). See in picture below. I have a carb rebuild kit so intend to take it off this weekend and have a good look over. What is the general view on best way to blank off unwanted vacuum's, is it as shown?
Thanks for help.
Ian
Ian
'83 GTC
ard126k
GTC 374
Post by ard126k » Thu Sep 12, 2019 7:58 pm
I'm not sure if 4mm is the correct size but something like this would do.
https://www.ebay.co.uk/itm/4mm-End-Caps ... LhZGgNscGw
monkey135
GTC 374
Post by monkey135 » Sat Sep 14, 2019 1:31 pm
Hi, so I got the carb off and I have a question on the spacers at the base. There are 3 spacers/plates (in first picture right to left = carb to manifold) all with gaskets on both sides apart form the last one which sits directly on what appears to be a plastic type thick spacer (2nd photo) still on the manifold. So that's 3 gaskets.
First question, my rebuild kit (genuine weber) only has 2 gaskets and they are different. One big hole (right below) instead of 2 small (left below). Is this correct and do I need one more like this or 3 like original?
Second question, the last plate has a 'peaked' region at the rear pointing up (some kind or restrictor/deflector), in my head this peak would be better pointing down given the air flow direction (or being removed altogether). Does anyone know which way round it should be? This could explain why it struggles at higher rpm or I could be completely wrong.
Any help massively appreciated, keen to get it together and back on before the sun disappears the winter.
Ian
Ian
'83 GTC
ard126k
GTC 374
Post by ard126k » Mon Sep 16, 2019 5:48 pm
Can't help with the gaskets but the GTC parts book has a drawing which seems to show the 'peaks' downwards. But it's partly hidden and not very clear.
monkey135
GTC 374
Post by monkey135 » Sat Sep 21, 2019 8:57 pm
Hi, so thanks to ard126k for the suggestion, I had a look at the parts book but now I'm more confused. The image shows only an 'intermediate flange -11' and a 'diffuser -15' as well as gaskets between the carb and manifold. The diffuser is shown a different way round to mine so I'll swap that.
However the thing I'm most puzzled by is that I have two extra bits. A metal plate and a plastic isolator/spacer (circled in photos).
Does anyone recall their working setup with a weber? Is it as the book or like mine with a plastic spacer and extra metal plate? Also does anyone know which way up the diffuser should go?
Ian
Ian
'83 GTC
ard126k
GTC 374
Post by ard126k » Sun Sep 22, 2019 8:05 pm
This may not be any help but I have the same thin metal plate in the 'box of bits' that came with the car. I didn't fit it because I couldn't see where it would go or what it would do.
The plastic spacer is probably a heat insulator which is I think standard with Webers on Essex engines. Maybe the Cologne/Pierburg didn't need it so it's not in the parts picture?
tyke 1508
GTC 374
Post by tyke 1508 » Sun Sep 22, 2019 8:43 pm
Plastic 'spacer' fitted on my 38dgms Ian.
monkey135
GTC 374
Post by monkey135 » Mon Dec 30, 2019 1:18 pm
Hi, on to the next issue. Now it won't start, no spark. Isolated issue to the ignition module I think, followed various threads on this site to check coil etc. Pretty sure it's the module.
So 2 questions;
1) Is this one correct as a replacement?
https://rover.ebay.com/rover/0/0/0?mpre ... 3392214405
It doesn't reference the D8VE 12A199 A2C that is stamped on my current module. Although the other references are very close.
2) As an alternative has anyone done away with the original setup and replaced with an aftermarket lumenition, Accuspark or similar setup instead? If so is that a better option? The Accuspark seems to provide everything you need in one setup so I can do away with the ignition module and associated loom unless I'm missing something.
As always advice/opinions welcome.
Regards,
Ian
Ian
'83 GTC
GTC 374
Post by scimjim » Mon Dec 30, 2019 1:46 pm
Looks like the correct module - I got mine from Mark (gtcse8) though?
The loom for the module includes the ballast/eureka wire so you’ll need to modify it if you fit accuspark or similar - I cant see any benefit though tbh?
monkey135
GTC 374
Post by monkey135 » Mon Dec 30, 2019 2:01 pm
Thanks Jim, tried Mark but he has sold out.
I thought the Accuspark would allow me to get rid of a load of wiring associated with the ignition module as I read on other posts that the loom can also cause issues.
Ian
Ian
'83 GTC
