GTC exterior weatherstrip
KJF
Post by KJF » Tue Jun 18, 2019 9:03 pm
I need to replace the exterior weatherstrip that runs along the top edge of the door and stops water running down the glass as the ones on mine have gone brittle. It looks like a straight pull the old one out and fit a replacement. I have found the part online but just need to know whether I need the wide (255) or narrow (95A) strip.
Has anyone done this job before that can advise the correct one of these two please?
https://www.woolies-trim.co.uk/product/ ... atherstrip
https://www.woolies-trim.co.uk/product/ ... therstrip
Personally I think the wider of the two.
Loxford
Has thanked: 24 times
Post by Loxford » Thu Jun 20, 2019 1:52 am
Yes, I have done this.Graham Walkers supplied the proper seals.
Neither of those pictured are the same as the original. They may work but the proper component isn't that expensive.
G
GTC Ian
Post by GTC Ian » Thu Jun 20, 2019 8:06 am
I got mine from Nigel at QRG. Exactly the same profile as the one I removed
Members since 1984
KJF
Post by KJF » Thu Jun 20, 2019 8:23 am
Okay, thanks for advice, I will call them and get originals
