SE6A &SE6B steering columns
SJM
Post by SJM » Tue Mar 26, 2019 11:53 am
Does anyone know if the steering column assembly - the upper 'fixed' part that carries the steering wheel, not the universal-jointed lower part - is the same on the SE6A & SE6B please?
Stuart
SJM
Post by SJM » Thu Apr 04, 2019 10:31 am
Is there REALLY nobody out there who knows the answer??
Has thanked: 120 times
Been thanked: 847 times
Post by philhoward » Thu Apr 04, 2019 10:48 am
I'd say they are the same.
A quick look at the parts list would confirm which I have just done and yes, they are the same.
Geraint SabreGTCse5
Been thanked: 64 times
Post by Geraint SabreGTCse5 » Thu Apr 04, 2019 10:54 am
the internal solid shaft with the universal knuckle joint on one end and the steering wheel bolted to the other is the same but its hardly fixed. the outer tube that bolts to the cross rail and glassed to the bulkhead changed slightly through production but they are interchangeable between the 6a and 6b as a whole assembly. I have some spares if you need a picture.
Geraint
SJM
Post by SJM » Fri Apr 05, 2019 9:21 pm
Many thanks Geraint & Phil. That's what I wanted to know. I have a 6B parts book, but not a 6A.
Stuart
Has thanked: 178 times
Been thanked: 1231 times
Post by scimjim » Fri Nov 15, 2019 8:32 am
Stuart
parts manuals online here.
