VIN number I think.
peter
Has thanked: 27 times
VIN number I think.
Post by peter » Sun Oct 28, 2018 8:10 pm
Hi everyone. Found an alum plate with this number engraved. VIN number . 7L43182036795C129077E12. What can this tell me. I have tried to decode it from other posts to no joy.
Thanks Peter.
Has thanked: 186 times
Been thanked: 1267 times
VIN number I think.
Post by scimjim » Sun Oct 28, 2018 8:23 pm
7 = 1977
L = November
43 = Arcti/Everest white
182 = RHD, PAS, Manual overdrive
03679 = sequential chassis number
5C (typo, should be SC) 12907 is the sequential engine number, not sure what 7E12 is.
peter
VIN number I think.
Post by peter » Sun Oct 28, 2018 9:17 pm
Thank you for your help. Man that was quick. Peter.
VIN number I think.
Post by scimjim » Sun Oct 28, 2018 10:06 pm
I only needed to look up the colour code, the rest is easy :D
peter
VIN number I think.
Post by peter » Sun Oct 28, 2018 10:22 pm
It's easy when you know. Thanks again.
peter
VIN number I think.
Post by peter » Mon Nov 19, 2018 6:03 pm
Good evening lads. Help needed again. I be just received the VIN number plate. I'm having it stamped by my local Jewelers. My question. Regarding the above Vin number what information is printed.
VIN number.
Engine number.
Thanks in advance. Peter.
VIN number I think.
Post by scimjim » Mon Nov 19, 2018 6:13 pm
Why not use the original VIN plate?
Info needed is generally just VIN and engine
VIN: 7L4318203679
Engine: SC129077
peter
VIN number I think.
Post by peter » Mon Nov 19, 2018 7:19 pm
I have bought the scimitar VIN plate. The original was a home made job that was hard on the eyes. Bad effort by someone over the years. When I get a chance I have to look for the markings on the chassis. That will take some sanding. Always great full for your help.
Peter.
Has thanked: 130 times
Been thanked: 871 times
VIN number I think.
Post by philhoward » Mon Nov 19, 2018 7:22 pm
If it looks like it was engraved by a 3 year old impersonating a drunken spider, then that’s the original factory engraving..
peter
VIN number I think.
Post by peter » Mon Nov 19, 2018 7:34 pm
Phil it actually does. But my local nct centre won't accept it.
Peter.
VIN number I think.
Post by scimjim » Mon Nov 19, 2018 7:48 pm
This is an SE6 VIN plate (used by GW on a mk2 Sabre and stamped rather than the Reliant drunken etching)
peter
VIN number I think.
Post by peter » Mon Nov 19, 2018 8:24 pm
No mine was a lot worse than that.🤔
VIN number I think.
Post by scimjim » Mon Nov 19, 2018 8:52 pm
More like this?
peter
VIN number I think.
Post by peter » Mon Nov 19, 2018 9:23 pm
Yes scribed not stamped.
VIN number I think.
Post by scimjim » Mon Nov 19, 2018 9:49 pm
There are other SE6 in Ireland and I haven’t heard of this problem before? The Dutch insist on an additional plate because it doesn’t have something on (axle weights?)
