GTC water pump replacement
Fred Warwick
Post by Fred Warwick » Sat Oct 13, 2018 11:09 am
Morning All
I need to replace my water pump and looking at the parts diagrams it seems I will need pump and gasket, plus all the thermostat gaskets - is that right?
Been thanked: 840 times
Post by scimjim » Sat Oct 13, 2018 8:30 pm
Yep. I’d recommend the Ford (Capri, Granada, Sierra) 2.8 cologne Haynes manual for jobs like this as the Reliant books don’t have that kind of detail for the Cologne.
Jockyo
Post by Jockyo » Thu Oct 18, 2018 11:08 am
Hello Fred
I just did this job.
I would also suggest a new thermostat.
Its a little bit awkward getting the thermostat housings and gasket aligned for the bolts.
I held the gaskets with a small smear of grease and it worked perfectly.
Careful buying the pump as the pulley mount differs between cars from a round mount to a square ish one, have a look at current one
Rod
1981 Scimitar SE6B / 1972 SWB Series 3 / 1997 Discovery 300Tdi / Jaguar 24 yacht = My favourite toys!
Fred Warwick
Post by Fred Warwick » Thu Oct 18, 2018 12:52 pm
Cheers. All done now, I followed the advice of Dennis Nicholls a few years back - put blue hylomar on the rear thermostat housing/gasket then partly assemble everything else dry. Tighten the thermostat housing bolts to put pressure on the joint, leave for a while then dismantle all the front pieces and the rear housing is effectively glued in place making the final assembly much easier.
