GTC Hazard Switch
Andreas H.
GTC Hazard Switch
Post by Andreas H. » Sat Sep 29, 2018 6:56 am
Hello!
from wich 'Donor Car' is the hazard switch in the SE6A, GTC, etc.?
Andreas
Been thanked: 842 times
GTC Hazard Switch
Post by scimjim » Sat Sep 29, 2018 8:30 am
TR7 and possibly other BL cars of the era.
Been thanked: 210 times
GTC Hazard Switch
Post by AJL Electronics » Sat Sep 29, 2018 9:02 am
With reservations! TR7 etc do not have the legend window.
Been thanked: 321 times
GTC Hazard Switch
Post by peter freeman » Sat Sep 29, 2018 10:24 am
They can be taken apart and the contacts cleaned - which is probably all that is needed given the amount of use the switch gets.
Been thanked: 81 times
GTC Hazard Switch
Post by gtcse8 » Sat Sep 29, 2018 7:21 pm
Chuck it into an ultrasonic cleaner for 20min, allow to dryout and bobs your relative??
Andreas H.
GTC Hazard Switch
Post by Andreas H. » Sun Nov 04, 2018 8:26 am
Hello folks,
thank you for the informations and considerations. Sadly my problem is maybe a bit unsual, as the housing of the switch is broken. I unsuccessfully tried to find a new item. The only available switches seem to be the light-switch. Do you know a possible supplier? Or maybe someone has a good used, or even a new, switch for sale?
I'm at the NEC on Saturday...
Andreas
GTC Hazard Switch
Post by gtcse8 » Sun Nov 04, 2018 5:50 pm
Andreas what part of the housing is broken, perhaps a picture would be better.?
I keep NEW housings in stock, plus I have a few of the Chrome housings that the switches clip into??.
Regards Mark
TrevorG
Been thanked: 8 times
GTC Hazard Switch
Post by TrevorG » Sun Nov 04, 2018 5:59 pm
If your switch is faulty you can buy a new one without the window, carefully unclip the outer shells and swap over. I've just done this for my 6a light switch. Hey presto, new contacts and backlit.
GTC Hazard Switch
Post by gtcse8 » Sun Nov 04, 2018 6:36 pm
Trevor pm inbound
Djangoz
GTC Hazard Switch
Post by Djangoz » Mon Nov 05, 2018 12:22 pm
Regards Mark
Hi Mark,
I would be interested in getting hold of one of the chrome surrounds which go around pairs of switches. I think they would be the same as those on the Middlebridge wouldn't they?
Andrew
Andrew
MB60
GTC Hazard Switch
Post by gtcse8 » Mon Nov 05, 2018 2:10 pm
Hi Andrew
They should be the same, will check on MB 42 this afternoon and get back to you.
Djangoz
GTC Hazard Switch
Post by Djangoz » Mon Nov 05, 2018 9:20 pm
Hi Andrew
Thanks Mark - my broken chrome surround is around the electric window switches on the centre console. As a matter of fact - a further problem is that one of the window switches keeps trying to "squeeze" out of the bezel all the time. Would that problem be due to a damaged switch housing in addition to the obviously broken chrome surround?
I can't check at the moment as MB60 is in a local garage for some work to be done.
Andrew
Andrew
MB60
GTC Hazard Switch
Post by gtcse8 » Mon Nov 05, 2018 9:59 pm
Andrew it could be both reasons, the New housings and Chrome housing/Nacelle could be cracked or broken.
I have found that Reliant fitters ground/filed the chrome housings to get a better fit on the plastic switch housings.
Obviously the headlight legend can be swapped over for which operation you require.
switch housing.jpg (128.67 KiB) Viewed 470 times
switch housing 2.jpg (109.23 KiB) Viewed 470 times
switch housing 1.jpg (129.33 KiB) Viewed 470 times
Djangoz
GTC Hazard Switch
Post by Djangoz » Tue Nov 06, 2018 12:38 am
PM Sent Mark
Andrew
MB60
