Scimitar GTC Power Steering Rack
Rob Jones
Post by Rob Jones » Mon Aug 20, 2018 4:09 pm
Good afternoon All,
Having a think about the tubes on my soon to be received steering rack from Mark.
Is it possible to re-fab the hydraulic lines using aluminium - does anyone know if the Aluminium Tube will take the high pressure??
Had a look on the web, and its a tad vague.
Rob..
Been thanked: 854 times
Post by scimjim » Mon Aug 20, 2018 4:30 pm
You’ll be able to find alloy that will stand the pressure but it won’t stand much impact damage.
Been thanked: 326 times
Post by peter freeman » Mon Aug 20, 2018 4:53 pm
Thick walled copper is suitable
Been thanked: 473 times
Post by Roger Pennington » Mon Aug 20, 2018 10:52 pm
Alternatively, consider having PTFE-lined, stainless braided ones made up. (the same type of thing as aeroquip)
Rob Jones
Post by Rob Jones » Fri Aug 31, 2018 5:15 pm
Hi All,
Its a doddle, mild steel, bent this my first go :D :D
PAS Pipe.pdf
(61.05 KiB) Downloaded 49 times
Off to buy a flaring tool, if all goes well, I might start making pipes 8) 8)
Rob..
Been thanked: 87 times
Post by Coupe Racing » Mon Sep 03, 2018 4:37 pm
good luck with flaring that - with DIY equipment - but if you do succeed , you could be onto a winner
Good luck
