Se6a oil capacity
Green dream
Se6a oil capacity
Post by Green dream » Sat Aug 04, 2018 12:30 am
I noticed with a shock, yesterday, that the oil level in my Scimitar was right down to minimum on the dipstick. I hastily added 5 litres of oil and found that it is now way above maximum. Excuse my ignorance: is this a danger to the engine? Do I need to have some oil drained out?
Has thanked: 106 times
Been thanked: 806 times
Se6a oil capacity
Post by philhoward » Sat Aug 04, 2018 4:29 am
It certainly won’t do it any good. It’s possible the excess oil will cause seals to fail and also overheating - as well as burning it off.
I wouldn’t recommend starting the engine, put it that way.
Has thanked: 167 times
Been thanked: 1175 times
Se6a oil capacity
Post by scimjim » Sat Aug 04, 2018 8:35 am
Max to min on the dipstick is about a litre.
Se6a oil capacity
Post by Roger Pennington » Sat Aug 04, 2018 11:51 am
Yes, I think you have two alternatives - either drain it off, as you suggest (bear in mind you'll need a larger than usual container to catch it), or if that's not possible for some reason, suck the excess out through the dipstick tube with something like this, for example (note: other products/suppliers are available)
