URGENT help - power steering
Bikergonebald
Post by Bikergonebald » Sat Apr 21, 2018 12:55 pm
I’m trying to get ready for an event tomorrow. I’ve had the power steering pump off and had pirtek but a new flexible in to the old pressure feed hose.
After refitting it’s leaking where the power steering pipe screws in to the back of the pump. I took the pipe back out, made the threads were clean and free and the nut slid freely against the flared pipe then put it back together.
Same problem.
Can I or should I use any sort of sealer?
Kevin.
Kevin
Scimitar Se6a 1979
Honda CB900c
Post by Coupe Racing » Sat Apr 21, 2018 1:57 pm
Make sure the pump hasn’t cracked
Also try some PTFE tape on the threads but as you say they should mate without anything added
Steve_S
Post by Steve_S » Sat Apr 21, 2018 4:05 pm
ptfe tape the gas one its thicker
Been thanked: 89 times
Post by gtcse8 » Sat Apr 21, 2018 4:45 pm
Kevin there are Two types of flares on the output pipe, check which one you have.
The common one seals against a brass cone that's pressed into the housing.
The other type uses an oil ring against a squarish shoulder in the pipe, if the O ring has dropped off you will get leaks, same with the brass fitting in the early type if that has cracked or fallen out.
Bikergonebald
Post by Bikergonebald » Sat Apr 21, 2018 7:41 pm
Found the problem. Hair line crack in the steel pipe where it goes in to the pump, so that was a waste of money getting the flexibles changed in it. :(
Kevin
Scimitar Se6a 1979
Honda CB900c
Post by Coupe Racing » Sat Apr 21, 2018 8:03 pm
Crack was a fair bet
