Multi switch (Head/dip lights, indicator, horn)
simmit
Has thanked: 131 times
Been thanked: 8 times
Post by simmit » Tue Nov 28, 2017 8:57 pm
Can anyone say from which vehicle the SE6/ Middlebridge multi switch was sourced? If switch is no longer available then which is best alternative option for ease of wiring and fit? I've seen mention of Maestro/ Montego.
Geraint SabreGTCse5
Been thanked: 64 times
Post by Geraint SabreGTCse5 » Tue Nov 28, 2017 9:17 pm
some models of vauxhall chevette
Geraint
Has thanked: 176 times
Been thanked: 1223 times
Post by scimjim » Tue Nov 28, 2017 9:28 pm
Yep, chevette but some models may need a couple of the wires swapping over.
PlasticMan
Post by PlasticMan » Wed Feb 07, 2018 10:22 pm
An alternative is a late MGB switch (1977 on) if you cannot source the vaxuhall one. I know this because I have been experimenting! My original stalk is toast. The B one appears to be a good fit (has the correct collar to go on the steering column, has all the right features and will fit the metal plate of the original) but the plug end is incorrect, you need to save the original plug and re wire that (fortunately the loom colour coding is pretty much the same except the horn connections) and also the stalk itself looks a little different.
simmit
Post by simmit » Sat Feb 10, 2018 5:10 pm
Thanks Plastic. Sounds to be a good alternative.
giddo
Post by giddo » Tue Feb 13, 2018 10:54 pm
Can I ask PlasticMan if he knows of a special tool or technique to remove the pins from the 9 pin plug that mates with the SE6 / SE8 loom.
I too am trying to recover from failure of the Lights / horn multiswitch. Some wires may need to be moved about.
Mike Giddens
Servant to Reggie the Reliant
Has thanked: 79 times
Been thanked: 212 times
Post by gtcse8 » Wed Feb 14, 2018 9:33 am
That's the Small Sports fitment.
PlasticMan
Post by PlasticMan » Wed Feb 14, 2018 10:58 pm
In all honesty no! The plan is to chop the plug off the new switch and solder the new loom wires to the remains of the old one, giving me a correct plug (my old plug is okay I have already rigged it up to an MG multi switch to test). Although when I have done that I can then mess with left over plug and try and find out...
PlasticMan
Post by PlasticMan » Wed Feb 14, 2018 11:01 pm
Actually looking more closely at the pins they appear to expand after being pressed through the plug. It may be possible to squeeze the end with some very small needle nose pliers and pull the pin back through the plug.
Post by gtcse8 » Wed Feb 14, 2018 11:05 pm
The pins are held in place with barbs that can be pushed back to get the connectors out of the moulding.
PlasticMan
Post by PlasticMan » Wed Feb 14, 2018 11:22 pm
For reference purposes this is what a Chevette/MGB hybrid stalk set up looks like...
https://imgur.com/JGkM2zD
Not exactly pretty but it should do the job, I might have to get an MG washer stalk so its more matchy, matchy!
Post by scimjim » Wed Feb 14, 2018 11:58 pm
You can get extract tools for the barbs on the pins but an instrument screwdriver works perfectly.
Post by scimjim » Thu Feb 15, 2018 12:01 am
Like these
Been thanked: 297 times
Post by AJL Electronics » Thu Feb 15, 2018 8:37 am
I have a small length of new brake pipe that does that job.
Bikergonebald
Post by Bikergonebald » Mon Jul 23, 2018 4:49 pm
From taking these apart does anyone know if the horn switch is at the steering column end or in the stalk?
My car has started sounding the horn by itself.
Kevin
Scimitar Se6a 1979
Honda CB900c
