V3.2 problems
Can't register?
Ian
Been thanked: 52 times
V3.2 problems
Post by Ian » Thu Jul 27, 2017 10:02 am
Coupe' Racing wrote:
Thu Jul 27, 2017 9:22 am
preferred their old style
The icons in use today are the same as previously used for the scimitarweb theme. There was previously the ability to choose other themes in the user control panel, but not at present.
Are these the icons you prefer and were used to?
Ian
ScimitarWeb WebMaster
RSSOC 453
Been thanked: 87 times
V3.2 problems
Post by Coupe Racing » Thu Jul 27, 2017 10:04 am
Yes the classic style was easier to read especially on a phone
Been thanked: 540 times
V3.2 problems
Post by philhoward » Thu Jul 27, 2017 10:25 am
I think it's a change in this version, but the "standard" (which is what you were using before, Steve) format reverses the view - the name appears on the right hand side.
V3.2 problems
Post by Coupe Racing » Thu Jul 27, 2017 11:03 am
Ok so how can I view like I did before
alan.wells
V3.2 problems
Post by alan.wells » Thu Jul 27, 2017 5:55 pm
Hi All,
Gavin wrote
"Hi,
Should the empty column on the right hand side have the last poster, date and time?
Gavin"
I still have no info in this right hand side column, Ian, your following post say It should now, am I doing something wrong, and I'm using the Classic style.
Well-done to all involved on this mission
Kindest Regards
Alan
SST 18Ti
Motorhome
1926 Bullnose Morris
3/4 coupe with dicky
( project looking good )
M/N 5637
td99
Been thanked: 22 times
V3.2 problems
Post by td99 » Thu Jul 27, 2017 9:05 pm
I like that list of quick links at top left, but in the long term it would be nice if the "Your Links" link showed only your own posts, not a list of threads in which one has posted somewhere..
Love the drag'n'drop for pics.
Thanks to Ian and the team for all the hard work!
Trevor - 1800Ti daily driver
1800Ti DET project, RAV4
Been thanked: 854 times
V3.2 problems
Post by scimjim » Thu Jul 27, 2017 9:24 pm
As with the previous version, click on any username (including your own) to access their profile where you can get a list of their posts ('search users posts')
V3.2 problems
Post by greeny » Thu Jul 27, 2017 10:09 pm
Having an issue since the upgrade I randomly get kicked out and have to log back in, even when I click k the "log me in every visit" Is this just me or an android issue or is it a glitch in the upgrade?
Ian
V3.2 problems
Post by Ian » Thu Jul 27, 2017 10:20 pm
No problem with the new software. If your browser handles cookies properly it should be fine. The testers and myself haven't had any problems.
Ian
RSSOC 453
V3.2 problems
Post by philhoward » Thu Jul 27, 2017 10:24 pm
Is this being in one location or when you are out and about, switching between different wifi networks and mobile areas, greeny? If so, then it's been the case for a long time where you end up with several different IP addresses in a short amount of time then it will lose track and log you out.
V3.2 problems
Post by greeny » Fri Jul 28, 2017 8:04 am
It's with out moving Phil (not even from the couch!!)
It's taken me 3 attempts to write this post as its kicked me out didn't happen before update. I knew about the moving between ip address as I have found that for a while.
alan.wells
V3.2 problems
Post by alan.wells » Fri Jul 28, 2017 1:40 pm
Hello,
I have tried to upload pictures earlier in non-technical section, I wrote my script, then dragged and dropped my pictures, which were shown in the attachment section, I didn't put a script in this section, but then clicked submit, but script only shown and no pictures, all pictures were resized as I have done in the past.
Anyone know where I'm going wrong
Alan
SST 18Ti
Motorhome
M/N 5637
V3.2 problems
Post by philhoward » Fri Jul 28, 2017 2:08 pm
Alan,
I've done a few screenshots which might help:
1. Select your picture from (in this case) my Windows Explorer window
Drag and Drop Stage 1.JPG (154.51 KiB) Viewed 1505 times
2.Drag it over to the box where you normally write your text, then let go of the mouse (Copy and Paste doesn't work - I tried it :))
Drag and Drop Stage 2.jpg (153.5 KiB) Viewed 1505 times
3.That should then show the filename in the box that will now appear below
Drag and Drop Stage 3.JPG (26.63 KiB) Viewed 1505 times
4. Click on the "Place inline" button to add it into the reply box - handy if you want to add text around it
Drag and Drop Stage 4.jpg (135.29 KiB) Viewed 1505 times
If you're unsure at any stage, see what the "Preview" button gives you.
If you miss out step 4, it will still show the pictures (or should - it certainly did during testing) but maybe not in the order you want.
If something goes wrong along the way, let us know how far you get.
alan.wells
V3.2 problems
Post by alan.wells » Fri Jul 28, 2017 3:06 pm
Phil, I can drag & drop, I have my image in JPG and its size below, but do not have the place inline facility on the same line or anywhere, where your inline button shows, I have the delete file button instead
Alan
SST 18Ti
Motorhome
M/N 5637
alan.wells
V3.2 problems
Post by alan.wells » Fri Jul 28, 2017 4:33 pm
I've just managed to upload on my tablet, all ok there, but mob phone wont allow picture to be added due to the image being to large, but I'm resizing the image and trying again on the desk top.
Alan
SST 18Ti
Motorhome
M/N 5637
