Posting and getting 'error' page up?????
Can't register?
Datsundrew
Post by Datsundrew » Mon Apr 17, 2017 7:07 pm
Hi, I'm getting ever more frustrated with trying to post. I seem to have no problem putting up pictures, but if I try to write text I get an error page come up. Occasionally, if I log out and back in I can do it, but I am unable to copy and paste, so after spending time explaining the pictures and progress, I loose the lot! Hence I just end up bombarding my build thread with pics. Does anybody else have this problem?
Been thanked: 840 times
Re: Posting and getting 'error' page up?????
Post by scimjim » Mon Apr 17, 2017 7:52 pm
Haven't had any problems since the initial glitches after the recent upgrade. There's a few standard tricks to try - first is to delete all board cookies (bottom right), the second is to see if you're logged in on a non-secure connection (http instead of https) - just type http:// in front of www.scimitarweb etc.
If you post it in forum issues, Ian (the webmaster) is more likely to see it and it's handy if you state which OS and version you're using.
Been thanked: 319 times
Post by peter freeman » Mon Apr 17, 2017 7:52 pm
I get error messages when I try to post pictures without words - the opposite of what you report. Try writing the words - post them then post the pictures by themselves - might work.
Post by scimjim » Mon Apr 17, 2017 7:58 pm
As you're posting on multiple forums Andrew, I'm surprised you don't write it in word and copy the lot?
Datsundrew
Post by Datsundrew » Wed Apr 19, 2017 11:13 pm
still can't post.....
Datsundrew
Just wrote a few sentences, error again.
Datsundrew
Post by Datsundrew » Wed Apr 19, 2017 11:15 pm
I've tried copying in word, won't allow. More than 1 line written = error page!
Post by scimjim » Wed Apr 19, 2017 11:49 pm
Definitely a problem your end mate - what OS and browser are you using?
Datsundrew
Post by Datsundrew » Thu Apr 20, 2017 12:02 am
No idea, what does an iPad use? I'm not good on computers, no longer have a pc, so that's not an option Never have trouble anywhere else. Not got a problem previously or on other sites, so guess my posting days here are coming to an end.
jag12
Has thanked: 17 times
Post by jag12 » Thu Apr 20, 2017 12:49 am
Having the same problem using iPad
Can post a new post but a reply on existing post results in a error page
GTC GOC383W. GTE 6a PFG814R. SSI 1600. B46SNX
Been thanked: 534 times
Post by philhoward » Thu Apr 20, 2017 5:13 am
One thing I did spot is your use of emoticons - don't know if it's a problem as yet, but instead of using the ones on the iPad, the forum needs its own "code" ones instead.
I'll keep digging from my side Drew - thanks for the info you sent but I've just not had chance to dig any deeper yet.
Post by scimjim » Thu Apr 20, 2017 7:26 am
If you click on the address bar where it says "scimitarweb.co.uk" it will show the whole address as something like
http://www.scimitarweb.co.uk/sgwrs/viewtopic.php?f=17&t=35911&view=unread#unread
Does yours say https at the start? If so, try forcing it out of secure mode by deleting the s, then try posting something.
Post by scimjim » Thu Apr 20, 2017 7:30 am
If you go to "settings", under "General", in the "About" menu will be a version number.
Post by philhoward » Thu Apr 20, 2017 8:51 am
Datsundrew wrote:No idea, what does an iPad use? I'm not good on computers, no longer have a pc, so that's not an option Never have trouble anywhere else. Not got a problem previously or on other sites, so guess my posting days here are coming to an end.
Drew,
Have replied direct via email but having been able to replicate the fault from your text you sent me, it's the emoticon (smiley) which is causing the forum software to have a bit of a fit. If you use the smileys that the "Post a Reply" page gives you, you should be fine from now on. :D (that's : D with no space between by the way).
Datsundrew
Post by Datsundrew » Thu Apr 20, 2017 11:16 pm
That's brilliant! Thanks for your efforts on working this out. I'm now going to write a paragraph ant then post it to see if it works. I'll shy away from using any smileys in future to keep it simple. I had a day off yesterday to get a day on the car, my biggest problem is the sump as it's way too deep, but I've found a w124 sump on eBay and bought that as it should me shallower ( will have to modify the oil pick up) my next issue is trying to get the engine and box angle to match the prop.......without ending with a power bulge in the bonnet!
