GTE rear light nylon/plastic fixing 'clips'
Locked
cb500t
Post by cb500t » Sun Dec 16, 2018 7:09 pm
I don't know how to describe the items, but they hold the actual light unit to the bodywork,must be about 6-8 per light unit...after a source please...T.I.A
Has thanked: 154 times
Been thanked: 1051 times
Post by scimjim » Sun Dec 16, 2018 7:21 pm
Do you mean the brass(?) knurled nuts? Definitely not plastic as they corrode to the studs in the lights.
cb500t
Post by cb500t » Sun Dec 16, 2018 7:27 pm
Mine look remarkably like plastic, but they are so weathered it could be swiss cheese quite frankly,I know they were manufactured with step in them reducing their diameter, they are certainly knurled..
cb500t
Post by cb500t » Sun Dec 16, 2018 7:29 pm
Or is their a better option that won't weld itself in place??
Has thanked: 189 times
Been thanked: 37 times
Post by willholderogri » Sun Dec 16, 2018 7:50 pm
I fitted m5 nutserts in my body work and mushroom head bolts to hold the lights to the car then I modified the lens in the same way so that the whole assembly can be removed from the car from the outside. Then topped them off with LED panels instead of bulbs
Post by scimjim » Sun Dec 16, 2018 8:37 pm
If you’ve saved or repaired the original studs, I’d probably use small nylon wing nuts to refit?
cb500t
Post by cb500t » Sun Dec 16, 2018 11:08 pm
Found a whole pile of knurled fixings on ebay made of nylon and thats the way I think I will go ...to save me some measuring, anyone know the stud diameter?
MadMax
Post by MadMax » Mon Dec 17, 2018 6:48 am
Manual says they are number 8 UNC
Max Benton
Reading, Berks
'Zeus' - Yellow SE5a
Post by scimjim » Mon Dec 17, 2018 8:26 am
I would have guessed at UNF (around 1/8”) - or possibly a BA size?
cb500t
Post by cb500t » Mon Dec 17, 2018 9:41 am
Thank you all...
Pepe
Post by Pepe » Mon Dec 17, 2018 9:46 pm
I saved all the original Metal inserts in the lenses, filed them flat, soldered a M3 hex spacer to them or drilled and tapped a M3 thread into them, where still in good shape.
Then I uses stainless M3 Bolt (guess they where 60mm?) some plastic hex spacers screwed onto them for better handling and some stainless washers.
Then I bolted these right into the m3 Holes in the lense: Through the zinc housing and seals and bolted them carefull to not snap the M3...
Depending on how collapsible your seal is this lasts ok. The M3 threaded Metal parts retain well against the zinc housing and body.
Bit fiddly but was worth the effort.
Like so:
1975 SE5a restoration link
Image Image
Has thanked: 37 times
Been thanked: 164 times
Post by gtcse8 » Fri Dec 21, 2018 8:53 pm
Would help if we knew which GTE we are talking about?.
The early GTE Lucas 782 used flat nuts and the later SE5a used mild steel slotted bobbins.
I have a few of the OE slotted bobbins, which were zinc plated, and some Brass knurled type that I made as an easier way of mounting the light units.
EX SST 1800Ti
Been thanked: 560 times
Post by Roger Pennington » Fri Dec 21, 2018 9:14 pm
Locked
