Coupe se4 (67) v6
Locked
backpain
Has thanked: 26 times
Coupe se4 (67) v6
Post by backpain » Fri Jul 13, 2018 11:05 am
Selling due to my health and down sizing home.I have owed for 4 years but started resto last year purchased from fellow member who told me engine was built by Scholar for a motorsports company Lansbury Haywood ,blueprinted with big valve heads.
I started by removing the body,Chassis was repaired ,cleaned ,painted with Rustoleum .A pair of s/steel exhausts by Langford with 3 branch manifolds refitted.New handbrake cable and adj spax fitted.
Engine Heads off cleaned waterways etc ,valves reground and found that inlet is 44.5 out 41 ,most core plugs changed,new parts fitted oil pump ,,Alternator ,,water pump,,petrol pump,,High torque starter,,Alloy timing wheel,,,coil plus lots of small stuff.
Brakes,, new discs,, recon 3 pot calipers fitted with green stuff pads..Girling mk2b brake servo powdercoated new seals/band .Main brake and clutch /slave all stripped, cleaned ,painted ,new seals.Frontend polybushed,,,gearchange bush kit fitted and overdrive service kit.
The inside is good ,front and back bumpers are not far off mint to very good
The car needs a respray badly,,the clutch plate is sticking is very difficult to get into gear so it will need a trailer to take home,Tyres are legal lots of tread but old I would not trust them.
I have not tried the overdrive don't think its wired up correctly.
Carb needs setting up and whole car needs someone to go round with a spanner and check for tightness .
I have driven it on the local road once since putting it back together, tax and mot free vhi
I have little idea of price so offers please ,pm me for more pics john
I have a set of bolt on wire wheels include fittings all new bar one I may add to deal if I get a good offer
Miss Moneypenny Coupe
briankenyon
Coupe se4 (67) v6
Post by briankenyon » Fri Jul 13, 2018 12:12 pm
Pm sent
Been thanked: 562 times
Coupe se4 (67) v6
Post by philhoward » Tue Jul 17, 2018 4:59 pm
Removed from sale.
Locked
