1977 scimitar gte Breaking
jag12
Has thanked: 17 times
Post by jag12 » Thu Sep 21, 2017 7:43 pm
As long as the power to weight ratio is not increased by more than 15% over the original :w
GTC GOC383W. GTE 6a PFG814R. SSI 1600. B46SNX
Has thanked: 23 times
Post by Alan SS1 » Thu Sep 21, 2017 7:51 pm
I'd have thought the first mini posted would fall foul of the UK rules regarding 'wheels not exposed' or whatever the correct rules are!!! :shock:
Has thanked: 113 times
Been thanked: 818 times
Post by scimjim » Thu Sep 21, 2017 7:55 pm
I did say current regs - whether the 15% PtW rule goes through remains to be seen.
Rook
Post by Rook » Sun Sep 24, 2017 3:13 pm
the sale and stripping of parts from this project is now on hold until a potential customer has made further arrangements, many thanks, will keep you all updated of status.
G T
Post by G T » Wed Jan 31, 2018 11:02 am
Hi Rook,
Is the interior of your SE6 still available? What colour/material is it?
George
Mrnick
Post by Mrnick » Tue Feb 27, 2018 10:25 pm
Headrests ??
Dcrosby13
Post by Dcrosby13 » Thu Mar 01, 2018 1:46 pm
im looking for a good passengers seat, mine is ripped.
I break stuff...... :w
Post by scimjim » Thu Mar 01, 2018 4:27 pm
OP hasn’t been logged in since last October so I would email him.
stevey
Post by stevey » Tue Mar 06, 2018 5:55 pm
Rear brake drums available?
metalmoth
Post by metalmoth » Sat May 26, 2018 6:09 pm
Do you still have the bonnet?
1982 SE6b factory black aka The Beast
What could possibly go wrong?
SJM
Post by SJM » Tue Jun 19, 2018 7:24 pm
Would you have the air filter box please?
Rgds,
Stuart
Been thanked: 77 times
Post by gtcse8 » Tue Jun 19, 2018 8:27 pm
Stuart this lead seems to have dried up.
I have various air boxes for some combinations of Carb fitted to Scims.
What exactly are you looking for?
SJM
Post by SJM » Tue Jun 19, 2018 10:16 pm
Hi Mark,
I am looking for a standard air filter assembly for an Essex with Weber carb.
Regards,
Stuart
Post by gtcse8 » Wed Jun 20, 2018 9:43 am
There are Two main types Stuart.
the early ones have a Manual flap on the inlet for summer/winter driving, the later ones use a vacuum take off from the carb itself to operate the heat flap.
I have an early one complete, and a later one that may need looking at.
I also keep in stock brand new filters for both types, they are the same Dia across the Essex fitting.
Pogle
Post by Pogle » Mon Jul 09, 2018 4:51 pm
Hello Rook
I am desperately seeking a Lockheed brake compensator it is fitted to the chassis near the gearbox, it is holding up my own restoration do you still have one ? if so would you be able to send it to me I will of course pay for it and the postage.
it has two pipes into the top from the master cylinder two out the bottom going to the front wheels and one pipe to back axle.
I hope that you can help
Many thanks Ian
Plymouth
Locked
