SS1 CVH instrument surrounds
Locked
Has thanked: 189 times
Been thanked: 1281 times
Post by scimjim » Sun Aug 27, 2017 1:16 pm
I have several of these and photographed them in answer to a wanted thread here.
From poor to excellent, first up this one has 3 holes for lights in the front, minor cracks at the lower mounting holes (which aren't visible when fitted), large cracks in the instrument surround area (again, not visible when fitted if taped from behind), a chunk missing - but no bubbles or warping, so would repair well. £15 posted.
Second has an impact crack on top and minor cracking at the lower holes and is missing the securing studs assembly (easily removed from your old surround and glued on) - again no bubbles or warping so would repair well. £20 posted.
Third up has been painted black, has a hole drilled in the front and larger cracking in the lower holes - no bubbles but it is slightly warped across the top - iirc it pulled straight when fitted. £20 posted.
Fourth has oversize and additional lower holes and a crack in the forward outboard corner (invisible when taped from behind). £SOLD
Fifth has cracks etc on lower securing holes, otherwise excellent £40 posted.
Sixth the same as fifth, £40 posted
Lastly a very late surround with the black inner section. The stud assembly needs gluing back on and the usual cracks around the lower holes, but otherwise excellent £50 posted
mikerf
Been thanked: 8 times
Post by mikerf » Sun Aug 27, 2017 7:13 pm
Hi Jim
Thanks for the first refusal.
Could I grab the £25.00 (Fourth) one please.
I know I've probably got your Paypal address somewhere but could you pm it to me again.
And thanks for looking these out and giving me first choice.
Mike
Post by scimjim » Sun Aug 27, 2017 8:32 pm
PayPal address sent Mike. I'll stick some alloy speed tape on the crack and box it tomorrow. Will post it sometime this week depending upon availability.
Locked
