gearstick pivot bolt se4/se5 partnumber 205778
Locked
geert van hout
Post by geert van hout » Tue Aug 08, 2017 9:58 pm
hello all.
for a restoration project i am looking for the gearstick pivot bolt on the 2 rail overdrive gearbox for a v6 coupe (but also fitted to se5's). it is the large bolt that is screwed in side ways to the gearlever. once in position it is secured by a small 1/4" unf bolt. somehow the thing is missing in action and i would be obliged to anyone who can help. thank you very much in advance.
in the attachment a drawing from the partlist: item 22.
pivot bolt.jpg (32.46 KiB) Viewed 1604 times
Has thanked: 178 times
Been thanked: 1231 times
Post by scimjim » Tue Aug 08, 2017 10:03 pm
Steve had some made here - not sure if he has any left and I don't know if he has enough biscuits to get more made but there's some good info in that thread.
geert van hout
Post by geert van hout » Tue Aug 08, 2017 10:24 pm
thanks jim. i'll chase that one up then. good evening to you
Gillsfan
Has thanked: 22 times
Been thanked: 38 times
Post by Gillsfan » Wed Aug 09, 2017 2:04 pm
I should have a couple left, I had 3 made and from memory only one was used. I have moved house since then :w I'll have a look and report back
1969 SE 5 Manual O/D Rat Rod
Been thanked: 123 times
Post by ScimmyMike » Wed Aug 09, 2017 3:04 pm
If Steve can't locate I've two 2 rod box's with gear sticks in my garage that I could cannibilize for you
Gillsfan
Post by Gillsfan » Wed Aug 09, 2017 3:09 pm
It's not good news unfortunately. My scimitar spares are reasonably well organised but despite checking every box I can't find them. The packing up of my garage before I moved was quite a rush, I was just shoving stuff in boxes. So there is still a chance or them turing up in with camping gear or Christmas decorations, but don't hold your breath.
Just seen mikes reply. Take him up on his offer, the ones I had made where good but not as good a fit as the original. When I had it made I didn't have an original to measure so they are close but not perfect. And I can't find them anyway.
geert van hout
Post by geert van hout » Thu Aug 10, 2017 5:30 pm
hello steve, mike,
the bolt turned up in one of the boxes my customer still had from other projects. one more problem solved. thank you all for your time and efforts but luckily this case is now closed. one more lhd coupe project on the way to getting finished soon.
many thanks again and a good weekend. cheers ,geert (scimitar-tvrcentre in the netherlands)
Locked
