UKC 7096 Low Fuel Warning Light Relay
Locked
Pepe
Post by Pepe » Tue Aug 08, 2017 9:39 pm
Hello guys,
I have realized that the missing unit under my dash is the Fuel Warning light "relay" .
Essential just a delay unit, but it is missing And I'd like to activate the low fuel funktion.
Anybody has a spare to polish up or rework?
Christian
1975 SE5a restoration link
Image Image
Has thanked: 189 times
Been thanked: 1277 times
Post by scimjim » Tue Aug 08, 2017 9:58 pm
Just out of interest, it's not a delay unit.
Been thanked: 437 times
Post by peter freeman » Tue Aug 08, 2017 10:02 pm
Check your tank sender - if it has three connections - earth - level and low level, the low level connection was available on the later senders and you can connect it to your low level lamp. Much better than the low level unit.
Has thanked: 52 times
Been thanked: 320 times
Post by AJL Electronics » Tue Aug 08, 2017 10:03 pm
It is a comparator. It can be reproduced using a basic op-amp like a 741.
Has thanked: 131 times
Been thanked: 872 times
Post by philhoward » Tue Aug 08, 2017 10:16 pm
I thought the Middlebridge one was - the 5a one is apparently the guts of a Smiths gauge with a set of contacts instead of a needle IIRC
Pepe
Post by Pepe » Wed Aug 09, 2017 7:33 pm
True about comparator...
But was lazy and didn't want to go soldering :) Plus you need a delay to avoid flickering on and off in corners.
Essentially the original par must have been bimetallic with adjustable kick in level, the bimetall spring adding the delay function to not flicker.
Are theses Units available new somewhere for affordable money?
My Late SE5a sender unit had the extra switch output for low level but I forgot to put the extra wire in the harness for it to the lamp, when I repaired and re-wrapped it....
:oops:
Delayed bimetall thingy is good enough. If not available here or new I need to build me a comparator...
Maybe other cars had the same thing to go looking on eBay?
Image Image
Post by scimjim » Wed Aug 09, 2017 7:38 pm
Post by scimjim » Wed Aug 09, 2017 7:44 pm
Out of stock everywhere it seems - even Rimmer Bros :-(
Pepe
Post by Pepe » Wed Aug 09, 2017 8:16 pm
Yapp :( Hence I asked... checked Rimmer several times.. Any idea of a similar unit maybe in the englisch automotive world? Maybe triumph?
Image Image
Post by Roger Pennington » Wed Aug 09, 2017 8:25 pm
Don't some/all (????) Small Sports have a low fuel unit, which may be the same type of thing?
Post by philhoward » Wed Aug 09, 2017 8:30 pm
That's more of a comparator but from what I remember not that well damped (compared to the 5a one)?
Post by philhoward » Wed Aug 09, 2017 8:34 pm
Post by scimjim » Wed Aug 09, 2017 8:34 pm
Yes, they're fitted to the TR7 (hence Rimmer Bros). Lots of Stag owners retrofitted them to dampen their warning lights.
Post by Roger Pennington » Wed Aug 09, 2017 8:44 pm
I wouldn't know, because I don't think I've ever seen my light, (if I've got one), and I have run it quite low sometimes (I forget that the tank's only half as big as a GTE), that's why there were question marks in my reply! :lol:
Pepe
Post by Pepe » Sat Aug 12, 2017 1:33 pm
noone has one left over?
Image Image
Locked
