Auto gearbox
Locked
kevincooper
Auto gearbox
Post by kevincooper » Tue Jul 25, 2017 10:40 am
Hi All
Does anyone have a C3 auto gearbox complete with bell housing they do not want? I can collect from South UK or from Scimfest.
Many thanks
Kevin
Kevin Cooper
Chairman
Insurance Valuations Officer
DVLA Liaison Officer
GTC
SE5a sprint car - Blue Dragon
SE5a waiting for restoration (Little Red Devil - Reg 666L)
Been thanked: 437 times
Re: Auto gearbox
Post by peter freeman » Tue Jul 25, 2017 12:29 pm
Time to be thinking about fitting a 4 speed auto box I think if your 3 speed box is duff. The 4 speed is much better.
Has thanked: 227 times
Been thanked: 52 times
Re: Auto gearbox
Post by willholderogri » Tue Jul 25, 2017 12:34 pm
4 speed ? will it fit in the place of a bw35 (SE5A) what make and model is it ?
thanks
will
Re: Auto gearbox
Post by peter freeman » Tue Jul 25, 2017 12:49 pm
I am told the MB box will fit - early A4LD with the same kick down as the 3 speed and the gear stick can be modified to use on the box if you cannot find a original MB one. I was also told that the 4 speed will fit onto the 3 speed bell housing Hopefully someone with more knowledge of auto boxes will confirm one way or the other.
Has thanked: 130 times
Been thanked: 871 times
Re: Auto gearbox
Post by philhoward » Tue Jul 25, 2017 1:05 pm
Essex or Cologne fitment, Kevin?
Has thanked: 52 times
Been thanked: 319 times
Re: Auto gearbox
Post by AJL Electronics » Tue Jul 25, 2017 1:10 pm
The A4LD has a Cologne bellhousing. I'm told that a C3 Essex bellhousing can be swapped, but I cocked up the one that I tried it out on!
hezekiel
Re: Auto gearbox
Post by hezekiel » Tue Jul 25, 2017 1:52 pm
I once wrote a topic regarding fitting the A4LD to Essex engine. It was in early 2010, probably has been erased already? A short summary is that you can make the 4 speed work with small modifications but fitting the lockup converter requires so much fabrication that I chose to keep the original C3 converter with it.
SE5a automatic '75
Mr. Heikki Salovaara, location 61 deg 51' N / 23 deg 09' E
Re: Auto gearbox
Post by willholderogri » Tue Jul 25, 2017 3:36 pm
do you still have a copy ?
Has thanked: 186 times
Been thanked: 1269 times
Re: Auto gearbox
Post by scimjim » Tue Jul 25, 2017 4:33 pm
hezekiel wrote:I once wrote a topic regarding fitting the A4LD to Essex engine. It was in early 2010, probably has been erased already? A short summary is that you can make the 4 speed work with small modifications but fitting the lockup converter requires so much fabrication that I chose to keep the original C3 converter with it.
here
kevincooper
Re: Auto gearbox
Post by kevincooper » Tue Jul 25, 2017 8:25 pm
Hi All
I need the bell housing and the pump to swop onto the A4LD to give me the 4 speed auto box. The gearbox in the Red Devil 5a was a Borg Warner not a Ford, so not very helpful.
Kevin
Kevin Cooper
Chairman
GTC
Re: Auto gearbox
Post by scimjim » Tue Jul 25, 2017 8:29 pm
It's not a straight swap as you'll see from Heikki's excellent thread.
briankenyon
Auto gearbox
Post by briankenyon » Sun Jul 30, 2017 9:34 am
Kev, I've got a auto box if interested I can bring it along with me to curbourgh
Brian
kevincooper
Auto gearbox
Post by kevincooper » Mon Jul 31, 2017 8:45 pm
Hi Brian
Many thanks, yes please, do you have the bell housing and torque converter as well.
Many thanks
Kevin
Kevin Cooper
Chairman
GTC
Auto gearbox
Post by AJL Electronics » Mon Jul 31, 2017 9:02 pm
I can bring some service items to Curborough if you wish? I have in stock for the C3:
Sump gaskets
Pan filters
Pan Filter seal
1st/rev servo small seal
1st/rev servo large seal
1st/rev servo gasket
AQF in 5 litres.
All of which ought to be done on the new 'box.
briankenyon
Auto gearbox
Post by briankenyon » Wed Aug 02, 2017 10:14 pm
Kev. I have the bell housing but no torque converter
Regards brian
Locked
