Scimitar Coupe Handbrake Adjuster
Locked
Graham914
Post by Graham914 » Fri Jun 28, 2019 7:37 pm
Hi
Im looking for a handbrake adjuster for my scimitar coupe, standard one i guess may be same.
I need the assembly that hooks to the bottom of handbrake through to the wheel that hooks onto tne cable.
Thanks Graham
Geraint SabreGTCse5
Been thanked: 51 times
Post by Geraint SabreGTCse5 » Fri Jun 28, 2019 9:41 pm
my coupe and my early 5 had the handbrake connector on the top, only way to adjust was drill extra holes and move the wheel. I fitted the the one on the bottom to both with no issues, I can sell on the bottom one if that is what you are looking for. PM me inf interested
Geraint
Graham914
Post by Graham914 » Mon Jul 01, 2019 10:47 pm
Hi
That looks like it should work.
What price do you have in mind.
Thanks Graham
Has thanked: 155 times
Been thanked: 1052 times
Post by scimjim » Mon Jul 01, 2019 11:36 pm
If Geraint doesn’t have one, get an alloy wheel (like the one on the early connector) to replace the plastic one, from Graham Walkers.
Has thanked: 190 times
Been thanked: 37 times
Post by willholderogri » Tue Jul 02, 2019 12:14 pm
I replaced the eyelet end with a stainless one from a boat company, and the other end with a stainless bolt. much easier to adjust after a years use. no corrosion .
David Tew
Been thanked: 59 times
Post by David Tew » Tue Jul 02, 2019 1:07 pm
My Coupe has the top connector without any adjustment so perhaps they were late Coupe/early SE5.
There is plenty of cable adjustment at the rear brakes and it's easily accessible :wink: .
Geraint SabreGTCse5
Post by Geraint SabreGTCse5 » Wed Jul 03, 2019 6:28 pm
Graham my PM to you has not been opened
regards
Geraint
Has thanked: 78 times
Been thanked: 707 times
Post by philhoward » Wed Jul 03, 2019 6:57 pm
regards
He’s not been on the forum since Monday.
Locked
